soundstream15 Posted June 18, 2014 Report Posted June 18, 2014 I am using rubber feet to lift my amp off the box but is there another way of making sure the amp doesn't vibrate? It's in a trunk sealed off so basically my options are very limited
timc31610 Posted June 18, 2014 Report Posted June 18, 2014 Here are my thoughts on mounting an amp to your box and it is just my opinion. If your box is built solidly enough there should be little to no flex on any of your box panels especially when compared to the rest of your vehicle. Secondly, I would assume that most amps are built to withstand a certain amount of vibration and if it mounted to a solidly built box you should be fine. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly
Bump4life Posted June 18, 2014 Report Posted June 18, 2014 i use grommits and a flat plastic washer to absorb vibration. i can take a pic later Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
Bump4life Posted June 18, 2014 Report Posted June 18, 2014 will do when im off work Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
