Identifying a electrical bottleneck
am i getting a demo??
Sorry Ross, she won't have amps until I get to Houston. Bring a m4 with you and we will go on a couple hour boom cruise.
damn guess ill drive my machine on down... lol jk
also didnt read cause im lazy but can you do 2 runs of 4/0 knu?
and by runs you mean 1 wire and not 1 pos wire and 1 neg wire is considered a run?
I'm allowed 2 total runs of cable for powering my system. They can be both power, they can be both ground (how that would work I don't know?) or they can be one of each. However if its larger then 1/0 .... Say skyhigh 2/0.. Or knu 4/0... Those would count as both of my runs.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
use this site to get an idea. under 3-4% is what id shoot for if I was you. If you are like me, I have under 1% voltage drop at 350A load
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.2557&voltage=14.2&phase=dc&noofconductor=1&distance=15&distanceunit=feet&amperes=300&x=40&y=11
Well that is interesting. According to that calculator... Even if I could supply a full 300a I would still be 13.5v at my amp because of the wire resistance.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
keep in mind that is with no heat in the equation. also what size conductor were you using and are you sure length was accurate?
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • Who's Online   0 Members, 0 Anonymous, 1149 Guests (See full list)
