Ignition 12V Switch Not Powered 2001 Chevy Sivlerado
I'm installing a amp in a 2001 chevy silverado and we pulled the head unit and everything was working fine before, but now whenever we go to put the headunit back in the red ignition switch wire is not receiving any voltage, I have checked the fuses both under the dash and under the hood and none are blown. Does anyone have any idea on what this might be? Should I just tie into a fuse under the dash that switches with the key? Sorry for the low quality post, this problem is wrecking my brain.
Maybe its because chevy didnt run an ignition wire tonthe radio and instead you should use the right module
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Now the remote wire is only reading 3.0 volts and it wont start the amp.....
  • 3 weeks later...
  • Who's Online   0 Members, 0 Anonymous, 1162 Guests (See full list)
