dawgs007 Posted June 26, 2014 Report Posted June 26, 2014 I currently have my Power Acoustik Mofo-122X wired to 2ohm. Would it be beneficial to switch up the wiring to 1ohm? The difference is 900W at 2ohm to 1200 at 1ohm. And if I provide the link (http://soundstream.com/store/car-audio/amplifiers/picasso/p1-1200d.html) could you guys tell me if the amp is stable at 1ohm? It gives 1ohm rms but doesn't state if it's 1ohm stable on a single 2-ohm DVC sub. A response and diagram on how-to would be great (I'm still in the learning process, immensely). Thanks in advance! Current Setup: 2002 Ford Focus SE (stock electrical) -Kenwood Excelon KDC-X397 -Infinity Kappa 6x9's in each door -Rockford Fosgate Prime R1200-1D -2 12" Rockford Fosgate P3D2 Backups: -12" Power Acoustik Mofo-122X in 36hz T-Line box -Soundstream Piasso P1.1200D
gibblegeibel Posted June 26, 2014 Report Posted June 26, 2014 http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=22#results here is a link on how to wire it to one ohm. the thing is your sub will getting more wattage since you are lowing the restinance in the sub. your amp is 1 ohm stable. the other thing it will sound louder and hit harder if i am not wrong.
hoit Posted June 26, 2014 Report Posted June 26, 2014 and run hotter. just be sure to use the DD-1 to get it set just right! make sure your using all the rated fuses as specified! and bump on! 2007 Chevy Aveo Ls sedan 2 Sundown Xv2 on scv4k @ .5 ohm 2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm Big Three, Three runs 1/0 power from front to back, 1 ground front to back Two runs ground from rear bank to chassis XS power d3100 upfront, 3 Odyssey 2150s in bank Singer 220 amp alt
truthsayer Posted June 26, 2014 Report Posted June 26, 2014 With that sub you can only wire to 4ohm or 1 ohm. So you probably are wired to 4ohm now. Then yes you will notice a difference wiring it down to 1ohm truthsayer
truthsayer Posted June 26, 2014 Report Posted June 26, 2014 Option 2 (series) = 4 ohm load Voice coils wired in series Recommended Amplifier: Stable at 4, 2, or 1 ohm mono truthsayer
dawgs007 Posted June 26, 2014 Author Report Posted June 26, 2014 So, this is the recommended diagram to make it 1ohm? Current Setup: 2002 Ford Focus SE (stock electrical) -Kenwood Excelon KDC-X397 -Infinity Kappa 6x9's in each door -Rockford Fosgate Prime R1200-1D -2 12" Rockford Fosgate P3D2 Backups: -12" Power Acoustik Mofo-122X in 36hz T-Line box -Soundstream Piasso P1.1200D
truthsayer Posted June 26, 2014 Report Posted June 26, 2014 So, this is the recommended diagram to make it 1ohm? yes truthsayer
dawgs007 Posted June 26, 2014 Author Report Posted June 26, 2014 So, this is the recommended diagram to make it 1ohm? yes Thanks a ton Truthsayer. This is the second topic you've helped me on! I'm currently on vacation but once I get home I'll let ya know if/what I change. Current Setup: 2002 Ford Focus SE (stock electrical) -Kenwood Excelon KDC-X397 -Infinity Kappa 6x9's in each door -Rockford Fosgate Prime R1200-1D -2 12" Rockford Fosgate P3D2 Backups: -12" Power Acoustik Mofo-122X in 36hz T-Line box -Soundstream Piasso P1.1200D
