box help
not sure if this is the right place to post this but i need help with a box for a 2012 impala ls. sundown x 15 and preferrably sub and port forward. if someone wanted to build a box and ship it i would pay then obviously. looking for low 30s right around 32-34 hz.
Gonna be A LOT of dough just to ship a box.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
When it comes to shipping boxes its not so much the weight as it is the size. I know FedEx and UPS have a fee table for size and fee table for weight and then they charge you which ever one is more.
To ship a box that size it can easily be over $100, it really depends on how far it has to go though.
Builds:
I'm in Minnesota I'm more looking for help with building one I'm not a pro and definitely not a novice but I would like if am wine built one I'd pay for sure
Max dimensions, and amp power are going to be needed for someone to sketch up something for you.
oh lawd.
Shipping is absolutely gonna kill you, even out of birch.. Even if you're not confident building yourself, see if anyone is local, would save u a ton of $$. Once u post up the max dimensions and if someone would be kind enough to design one for ya, just make sure once u build it to make a cardboard mock up first to make sure it fits through the trunk opening. I've seen it happen many times and have had customers that I've done builds for try to blame me for it not fitting.
U mentioned you wanted sub/port forward, I'm guessing through the back seat opening. Are u planning on completely sealing it off from trunk so it only fires into the cabin? If not I'd recommend doing traditional sub/port facing trunk lid w/ at least 4-6" of space from port to trunk lid and deaden the hell out of it.
2006 Hyundai Sonata Lx
- Alpine CDA-9885
- Rainbow CSX Comps
- (2) 12" Sundown Zv4
- Sundown 5K
- 4.6ft3 @ 33hz w/ 6" aeros sealed off in trunk
- 250a Singer alt, Kinetik 1400, (2) 2400s
- 150.4 @ Dash as of now
I was looking I to deadening the hell out of the lid upper deck and side panels but I just am playing around with ideas cause I would really like to seal it off with foam or something
So here is a suggestion to build yourself, just have the pieces cut free for you at home depot and glue them together yourself, you will just need a jigsaw for the sub cutout, power: to sub rated, amp subsonic filter to 28Hz, port clearance 4", figure is just an assembly guide:
NOTE: Dimensions are suggested so you NEED to verify the actually work. Also, If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 5315 Guests (See full list)
