Clayton Wehrer Posted June 27, 2014 Report Posted June 27, 2014 I need helping picking an amp for 2 Sundown e8v3's dual 2 ohms. Right now I'm running a Hifonics hfi1000.1d. Narrowed it down to these. Looking to keep it under $250. Thanks for the help. Stock electrical in a 98 Camry btw (80 amp alt). http://store.soundsolutionsaudio.com/products/crescendo-audio-symphony-s600-1-600-watts-x-1-mono-block-symphony-series-amplifier.html http://www.sonicelectronix.com/item_79533_Soundstream-PN1.650D.html http://www.sonicelectronix.com/item_68792_Precision-Power-i650.1.html
Guest Posted June 27, 2014 Report Posted June 27, 2014 crescendo. you wont be able to wire an amp to 1 ohm though. only .5 or 2 ohms with your dual 2 ohm coils.
mothra Posted June 27, 2014 Report Posted June 27, 2014 i'd stay away from the Crescendo. the other 2 amps are the same amp just different case. if nothing changes, nothing changes You don't know what you don't know, till you don't know
Clayton Wehrer Posted June 27, 2014 Author Report Posted June 27, 2014 I've heard good things about the Ion, mixed things about the Soundstream and zip about the Crescendo.
truthsayer Posted June 27, 2014 Report Posted June 27, 2014 http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22#results The link will show you your wiring options, .5ohm,2ohm or 8ohm. So odds are you will run at 2ohms, So i would be looking for an amp that does atleast 800rms at 2ohm. truthsayer
Jhunt94 Posted June 27, 2014 Report Posted June 27, 2014 A Rockford Fosgate Prime R1200-1D will do 800 watts rms at 2 ohms, and you can find them on ebay for around $220-230. Just another option that you could consider. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
Guest Posted June 27, 2014 Report Posted June 27, 2014 i'd stay away from the Crescendo. the other 2 amps are the same amp just different case. lol why?
Guest Posted June 27, 2014 Report Posted June 27, 2014 crescendo is a proven korean built company, them amps are nice those others, not so much
SonicElectronix Posted June 27, 2014 Report Posted June 27, 2014 NVX JAD1200 would do nicely http://www.sonicelectronix.com/item_40252_NVX-JAD1200.1.html www.sonicelectronix.com | Authorized dealer for Rockford Fosgate, JL Audio, Sony, Hifonics, NVX, Wet Sounds, Kicker, JBL, and tons more! Check out the exclusive SMD deals on this thread: Name your Deal & Exclusive SMD Promotions
