deebeeez Posted July 1, 2014 Report Posted July 1, 2014 First post on SMD Forums, usually am on Car Audio figured i'd try to use this one a little more as well! Looking at getting either a Sundown x12 or FI BL 12. I have a few questions Other than a little price difference whats the difference in power handling (They both say close to 1500 rms) Why one over the other? And finally on the Fi, how much of a difference is it loading it out with all the options on cooling, leads, etc etc. If you fully load it, it's about the same price as an X12 Thanks guys
Joe X Posted July 1, 2014 Report Posted July 1, 2014 Welcome, one is regarded as a sound quality sub the other as a low end monster, both will handle 2K if you handle them properly, the box specs are critical to sub performance so it's very hard to tell you to choose one over the other. Your personal taste is another factor nobody can comment on objectively. You should know that you can't seek to compare products on here so your thread won't live too long.
Kyblack76 Posted July 1, 2014 Report Posted July 1, 2014 Correct. Vs threads are not what is liked around here.. welcome to the forum. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
deebeeez Posted July 1, 2014 Author Report Posted July 1, 2014 Welcome, one is regarded as a sound quality sub the other as a low end monster, both will handle 2K if you handle them properly, the box specs are critical to sub performance so it's very hard to tell you to choose one over the other. Your personal taste is another factor nobody can comment on objectively. You should know that you can't seek to compare products on here so your thread won't live too long. Correct. Vs threads are not what is liked around here.. welcome to the forum. Appreciate the heads up guys! I wouldn't have known. Thank you for the feedback Also, which one was the more SQ one?
SMF93 Posted July 1, 2014 Report Posted July 1, 2014 BL but still should have a good amount of output. Fi Q is also a SQ sub
