Aero port question for 6cu box
You need two more ports and you need to account for the displacement for the ports. You won't have 3ft3 of airspace after installing the ports.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Iv never seen 8 ports for 2 15's. Not saying your wrong just seems odd to need 4 ports for 1 sub. My current box is at 38htz with 2 4x7 ports but either way thank you for the help
You need around 50 square inches of port for each sub.
If you use 4" ports it will take that many.
Just do basic math to find the area of shapes to 50 square inches.
If you get 50 square inches you will need all the ports to be 40 inches long.
10" port and something like 20-30" long all external.
sonotube/concrete forming tubes can be used for that.
oh and don't separate the chambers, you will gain a slight amount of volume.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
If he does 10" ports that is 57% more area he needs and will require a lot longer port for it to be tuned to 32 Hz, around 60" long if all of it was external...
One 10" port with a good 1" round over bit in a 6-6.25cuft net box would do. Rockford recommends 1 6" port per. A single 10" port exceeds Rockford's recommendation.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
You do realize that each sub is in its own chamber, right?
He can't even do it anyway.
Also, when I said it would be 60" long that would be 1 10" for a single 3 cube chamber.
  • Who's Online   0 Members, 0 Anonymous, 8410 Guests (See full list)
