Ryan Walker Posted July 9, 2014 Report Share Posted July 9, 2014 I'm looking at buying six orion xtrpro 15s dvc 4ohm. I have a decent knowledge of ohms and wiring but I'm stumped on how I can wire these down close to one ohm. They will be hooked to a sundown audio saz-3000d. If I wire some in series and some in parallel will those with higher ohms not sound or work differently than those with lower ohms or will it basically be whatever the end ohm load is will be how they all act? Link to comment Share on other sites More sharing options...
evermaxx Posted July 9, 2014 Report Share Posted July 9, 2014 1.3 Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
Ryan Walker Posted July 9, 2014 Author Report Share Posted July 9, 2014 1.3 That's what I was looking at. Wire all six sub's down to 2ohm per sub. Then three sets of two sub's wired back to 4 ohm power set. Then wire those three "sets" back down to a total ohm of 1.33 right? Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted July 9, 2014 Report Share Posted July 9, 2014 or you could make it a lot easier and series all 6, then wire all 6 in parallel to get 1.33. like so.... Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
Ryan Walker Posted July 10, 2014 Author Report Share Posted July 10, 2014 Of course, that would be the easy way, which is why it was troubling me. I kept trying to make this way harder than it is. Ok, with that figured out, how would I figure what my amp wattage would be now? The known rms for that amp is 800@4 ohm, 1600@2 ohm, and 3000@1 ohm (perfect world of course) I'm thinking at 1.33ohms it'll be about 2500 RMS maybe? And of course I hate to give up 500 watts so maybe I'll just stay with my 2 fi audio bl-18's 1ohm dvc wired at 1 ohm mono so I keep my total wattage. I was just trying to up my surface area of the subwoofer but I don't know which is better. Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted July 10, 2014 Report Share Posted July 10, 2014 cone area is funner, power/motor force is what hurts. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
Ryan Walker Posted July 10, 2014 Author Report Share Posted July 10, 2014 cone area is funner, power/motor force is what hurts. Hurts as in that nice feeling in your chest when you're hitting high dB's? Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted July 10, 2014 Report Share Posted July 10, 2014 Of course, that would be the easy way, which is why it was troubling me. I kept trying to make this way harder than it is. Ok, with that figured out, how would I figure what my amp wattage would be now? The known rms for that amp is 800@4 ohm, 1600@2 ohm, and 3000@1 ohm (perfect world of course) I'm thinking at 1.33ohms it'll be about 2500 RMS maybe? And of course I hate to give up 500 watts so maybe I'll just stay with my 2 fi audio bl-18's 1ohm dvc wired at 1 ohm mono so I keep my total wattage. I was just trying to up my surface area of the subwoofer but I don't know which is better. There is a difference between resistance and impedance. Your not going to stay at 1.3 ohm at all times, your speakers impedance will change with frequency. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Ryan Walker Posted July 10, 2014 Author Report Share Posted July 10, 2014 Ok, basically "in theory" if everything was created equal, a couple of sub's running low ohms max watts would be felt more than several sub's running higher ohms with less wattage? Link to comment Share on other sites More sharing options...
g2shuck Posted July 12, 2014 Report Share Posted July 12, 2014 Ok, basically "in theory" if everything was created equal, a couple of sub's running low ohms max watts would be felt more than several sub's running higher ohms with less wattage? Install dependent 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member Link to comment Share on other sites More sharing options...
