medwards420 Posted July 11, 2014 Report Posted July 11, 2014 I know they are rated @ 400 a piece but is this amp to much for them @2ohms
BigManAC Posted July 11, 2014 Report Posted July 11, 2014 On their website it says they are rated at 500wrms and the amp (if its the DXA1000.1) says it will do 1000 wrms at 2 ohms so if your final ohm load is 2 ohms at the amp then you should be fine judging by the manufacturers ratings. Links to where I got the info and numbers subs:http://www.kicker.com/CompVR amp:http://www.kicker.com/D_Series_Amps 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
medwards420 Posted July 11, 2014 Author Report Posted July 11, 2014 have the older dx 1000.1 but ya purtty close
medwards420 Posted July 11, 2014 Author Report Posted July 11, 2014 and that was for the cvr 15s..... those are 500 rms
BigManAC Posted July 11, 2014 Report Posted July 11, 2014 Well if the specs are the same then you should be fine. Just make sure to set the gains properly and you shouldn't have any problems. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw
Joe X Posted July 11, 2014 Report Posted July 11, 2014 Then it would be about 500W a piece wired to 2 ohm final load, as long as you have engaged your amp subsonic filter the subs will take the power.
medwards420 Posted July 11, 2014 Author Report Posted July 11, 2014 running sealed, dont need the subsonic filter
Joe X Posted July 11, 2014 Report Posted July 11, 2014 Subsonic filter saves you energy either way, is not only for mechanical control. Also kicker in sealed... only if you are lacking space. Anyways your gear will work together just fine, best of luck.
