High Output liquid cooled alternator???
Why not add a second alternator?
Hammerdown... 1%
I am not sure how the car would like having two alternators. I guess the second alt would have to be isolated from the rest of the vehicles electrical system since there is a plug going from the stock alt to the main wiring harness. I'd need to research it but still would rather have just 1 stronger alternator if possible.
What if I upgraded my battery to AGM and added a second AGM battery?
T2500-bdCP
PPI P900.4
And these two batteries,
http://www.remybattery.com/Intimidator-9A95R-Group-Size-95R-AGM-Battery-P9242.aspx
http://www.remybattery.com/Intimidator-9A48-Group-Size-48-AGM-Battery--P4550.aspx
180A alternator enough for music?
When I hear music, I fear no danger. I am invulnerable. I see no foe. I am related to the earliest times, and to the latest.
~Henry David Thoreau
Why would the car care if there's more than one alt? Tons of people do installs with 3+.
Hammerdown... 1%
Guess it's just because I've never done it myself before, and I know how electrically sensitive these cars are. How does it work? I mean, would I need to tap into the com port off the voltage regulator from the stock alt and split it off to a second alt and they just load balance off each other depending on electrical load? Or could the second alt be the self-excite type with a second run of 0AWG to the batteries in the back?
can do it either way but then your second alt runs full output all the time and will wear out faster. On the plus side your stock alt will run very small load and last forever..
Hammerdown... 1%
Alright, I clearly need to read up on the different ways to wire up a second alt. Thanks for the heads up about the second running at full output.
I heard back from Singer, cool guy I feel that I'd be happy to give him my money from talking with him, but unfortunately there are no upgrades available for my stock alt but at least he got back to me. Still waiting to hear back from the other guys but I suspect the same since the stator is pressed in and uses the external case as a "water block" so to speak.
I'm leaning towards upgrading to a 180A stock water cooled unit from an E65 and then adding a second 150-200A alt later on.
Just be careful about running higher RPM's. I dont know why but i've not had any luck with custom alternators holding together above 5500rpm. My singer unit blew up twice, mike replaced the rotor once and the second time I just had a local shop fix it.. but I havent put it back in since the second time either yet. The shop also put together a custom unit for me to test at higher RPM's since they were interested in what was happening and I blew that one up a couple times for them as well :)]
The stock pulley does help (took 7500rpm to knock out with large pulley) but you lose the low RPM output..
Hammerdown... 1%
Thanks again, I'll keep that in mind. I tend to drive it like I stole it.
I have the T2500.1bdcp at 1ohm and the biggest alt I could get for my car was 150amp, when driving I don't see anything under 13.8 hot and I only run two optima yellowtops, I think with a decent bank and a water cooled alt you might be ok?
  • Who's Online   0 Members, 0 Anonymous, 3140 Guests (See full list)
