orion xtr 3700.1
sbg
I got a bad ass 2000.2 also. Just have not hooked it up yet :)
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
Sponsored?
My real good friend is a orion dealer. And It just happens I work for his shop :)
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Isn't there an orion dealer in Bismarck? What's the hcca 10 d2 run for these days? Rms rating? Is it a real improvement switching to this black coil I've heard a little about
I don't know about the other dealers, yes the black coil is a improvement higher temp coil, and takes move power over the older models. Online price on a 10d2 is around 310$ in shop we have them at 425$
10" is 3" coil rated at 1500wrms
12"-15" 4" coil rated at 2500wrms
SPL versions are 4.5" coils
And rated 5000wrms
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
doesnt a bass knob have a cieling that is set at the amps gain itself. ?? like you can go as low or high as you want on the bass knob, but the highest setting is still only what you have the amps on board gain set at??
no
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Really? Not even if when you set your amp gains and such with your dd1 you do so with your bass knob maxed out? Pretty sure if done this way and you leave your deck settings alone it will work as so
  • Who's Online   0 Members, 0 Anonymous, 4658 Guests (See full list)
