Swampy Posted July 19, 2014 Report Posted July 19, 2014 For those that dont know, I run (2) DC Audio m1 level 5 18s that are 2 ohm DVCs and I have them running at .5 ohms on a single AQ 2200. I just recently recieved a second AQ 2200 from UPS and it came out of the box looking like someone hit it with a hammer. One of the mounting feet was bent upward touching the body of the amp and both RCA inputs were totally broken. The left input was hanging on by a thread, and the right input is totally MIA. My question is this...my overall goal was to strap the amps together in the first place, but the AQ only has one set of inputs and no outputs whatsoever, then it has what looks like one single RCA jack on the other side of the amp with a switch that reads "slave." Im curious if its possible to use the damaged amp as a slave amp so that I can work my way around the damaged RCA jacks. If this is possible, what im looking for is an explaination to how id go about getting signal from the master amp to the slave amp. The package was insured for more than I paid for it, so once the claim goes through I should have the amp and the money. Worst case scenario, ill have to find another one or pay to have this one repaired...but I have seen where people who strap their amps dont have RCAs running to the slave amp at all. If anyone has any insight on this at all, id appreciate your advice. I don't claim to know how to solve anything, I just practice the basics. There is nothing worse than wasting hours over a problem that should have taken 5 mins. Anything I post and claim to know, I know simply because of a lesson learned from a mistake on my part.
ChevyBoy95 Posted July 19, 2014 Report Posted July 19, 2014 I got you, give me a second to draw something in paint. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Swampy Posted July 19, 2014 Author Report Posted July 19, 2014 I got you, give me a second to draw something in paint. awesome man, thanks. I don't claim to know how to solve anything, I just practice the basics. There is nothing worse than wasting hours over a problem that should have taken 5 mins. Anything I post and claim to know, I know simply because of a lesson learned from a mistake on my part.
OrionStang Posted July 19, 2014 Report Posted July 19, 2014 Why not one amp on each sub at 1 ohm? And why only a 2200 per sub? Note: I am not a fan of strapping, don't see the point if you have two subs and two amps. SMD Super Seller My Feedback Thread
Swampy Posted July 19, 2014 Author Report Posted July 19, 2014 Why not one amp on each sub at 1 ohm? And why only a 2200 per sub? Note: I am not a fan of strapping, don't see the point if you have two subs and two amps. I said in the post that the RCAs on the second amp are totally screwed up, so thats the answer to your first question. and as to your second question, its a two parter. the m1 series is set for 2k rms, and the other part is budget concerns. I don't claim to know how to solve anything, I just practice the basics. There is nothing worse than wasting hours over a problem that should have taken 5 mins. Anything I post and claim to know, I know simply because of a lesson learned from a mistake on my part.
ChevyBoy95 Posted July 19, 2014 Report Posted July 19, 2014 on the damaged amp, as long as the single RCA input that is by itself still is ok, you can strap them. That is how the slave gets input. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
ChevyBoy95 Posted July 19, 2014 Report Posted July 19, 2014 Why not one amp on each sub at 1 ohm? And why only a 2200 per sub? Note: I am not a fan of strapping, don't see the point if you have two subs and two amps. try actually helping.... not trying to be an ass, but #1 was out of the option with broken RCA inputs, and #2 is a personal opinion. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Swampy Posted July 19, 2014 Author Report Posted July 19, 2014 on the damaged amp, as long as the single RCA input that is by itself still is ok, you can strap them. That is how the slave gets input. this is really helpful man, thanks a lot. so if i understand right, the master amp gets the inputs from the HU, and then from the slave input on the master, it goes to the working rca input on the slave amp. is that right? I don't claim to know how to solve anything, I just practice the basics. There is nothing worse than wasting hours over a problem that should have taken 5 mins. Anything I post and claim to know, I know simply because of a lesson learned from a mistake on my part.
Swampy Posted July 19, 2014 Author Report Posted July 19, 2014 on the damaged amp, as long as the single RCA input that is by itself still is ok, you can strap them. That is how the slave gets input. oh wait, i just now read as long as the single RCA input that is by itself. i understand completely man, thanks a lot for the help. I don't claim to know how to solve anything, I just practice the basics. There is nothing worse than wasting hours over a problem that should have taken 5 mins. Anything I post and claim to know, I know simply because of a lesson learned from a mistake on my part.
Swampy Posted July 19, 2014 Author Report Posted July 19, 2014 just fyi, this is how the amp came out of the box looking. its pretty obvious that it took a pretty solid hit. I don't claim to know how to solve anything, I just practice the basics. There is nothing worse than wasting hours over a problem that should have taken 5 mins. Anything I post and claim to know, I know simply because of a lesson learned from a mistake on my part.
