Single Skar VVX8-D4 question
Installed system:
Focal comps up front
Zapco iforce comps rear
Zapco AG360 4ch amp powering comps (50wX4)
Skar VVX8 D4 sub
Zapco 500.1 amp powering sub (500wX1)
My question is this: The sub just does not seem like its able to keep up with the rest of the system. It seems to me that I can use another 500 watts of power, or another sub. Sure, the sub sounds fantastic, bass is deep and clean. But it seems like the bass cannot keep up with the mids/highs. Anyone have any experience with using a single 8" sub with a 4channel system? its my first. I usually use two 12's or 15's, and did not ever experience a lack of bass, even with the same amps....
thanks
Small cone area
Small power
Can only get so loud
What kind of box is your sub in?
How is your sub wired?
Your sub is a d4 so if you wire them parallel you'll be at 2 ohms so your not seeing 500 watts your most likely seeing less than half (depends what your amp is rated at 2ohms)
Installed system:
Skar VVX8 D4 sub
thanks
its an 8" sub. you wouldnt expect 800hp out of a geo metro would you?
Owner of BigAss Ports
Small cone area
Small power
Zapco Reference 500.1 mono amp.
350wrms @ 4ohms
500wrms @ 2ohms
yes I have both vc's in parallel for a 2ohm load.
I can hook up my RU D4 12" sub and get a LOT more bass, and also with my 15. Just the 8 is lacking output.
But I am getting plenty of replies stating that a single 8 will not put out much, so I am satisfied with that.
Installed system:
Skar VVX8 D4 sub
thanks
Its more about the difference (to me) of powering a 12 or 15 sub with the same amp, which pounds plenty, versus this little 8. Its the first time I've tried a single 8" sub in a car, and needed to get some feedback about what I should be expecting. i figured I should be getting at least 400hp out of a metro, so to speak.
Installed system:
Skar VVX8 D4 sub
thanks
you should be expecting significantly less output than a 12 or 15, since it is significantly less subwoofer than a 12 or 15.
  • Who's Online   0 Members, 0 Anonymous, 1909 Guests (See full list)
