MD7786 Posted July 25, 2014 Report Posted July 25, 2014 I currently have the big 3,pioneer AVH 4300,2 yellow tops, jl 1000/1 and a psi 15 at 1500 rms on stock alt. Wondering if I could hook up a alpine 500 watt amp and throw a 8,10, or 12 in separate box in trunk with it. To get a Lil more. Thoughts.
Guest Posted July 25, 2014 Report Posted July 25, 2014 dont mix woofers. if its not loud enough then buy bigger equipment.
SlamminBeats Posted July 25, 2014 Report Posted July 25, 2014 you have alot going on here. Your talking about subs/enclosures when the subject is about electrical and how much can you push that alternator. i run a stock alt on 5k and ive seen people run even more on one. Its not recommended but its doable. As for adding another random sub and amp combo with an existing setup, thats highly advised against.
MD7786 Posted July 25, 2014 Author Report Posted July 25, 2014 Don't mix as in size or brand or both. And what would you recommend amp wise for more . I've heard the 1000/1 pulls hard on electrical
MD7786 Posted July 25, 2014 Author Report Posted July 25, 2014 Thanks slammin. So maybe bigger amp and another psi?
Kyblack76 Posted July 25, 2014 Report Posted July 25, 2014 Let's start with the question you have. What car/alt ? Some OEM alts are damn fine. Most are turds. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
SlamminBeats Posted July 25, 2014 Report Posted July 25, 2014 Thanks slammin. So maybe bigger amp and another psi? bigger amp or another 1000/1 Keep all mono amps identical keep entire subwoofer stage identical.
Aj11 Posted July 25, 2014 Report Posted July 25, 2014 The jl slash Amps are very power hunhungry things! i had 2 of the 500/1s and i would drop into the low tens on a 136amp alt. sold them got a ct 1400.1 and never dipped below 13. personally i would get a more efficient amp and not try and throw random subs together! jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
MD7786 Posted July 25, 2014 Author Report Posted July 25, 2014 I have a 2001 v6 camry. I believe a 80 alt.
MD7786 Posted July 25, 2014 Author Report Posted July 25, 2014 Ok and what is a good durable amp that's got power and won't cost a new car to buy.
