hdc3 15 on a ct sounds 1400.1d box help
elgrande
I need help designing a ported box for my hdc3 15 soundqubed im going to be running a ct sounds 1400.1 to it if anyone can help me out it would be much appreciated thank you!
This are my max dimentions I would like the sub and the port facing the same way wich would be up!
Hight:24
Lenght:32 maxx
Width:23
Would like it to be tunned around 34htz
So here is a suggestion within your dims, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 4", figure is just an assembly guide:
Oh ok thanks would it make a difference if I center it or wich would you recommend me
If you place the sub in the center you are not going to be able to place the brace (top to bottom) shown, that's why I would just place it where the figure shows. Now if the question is that a center placement could alter the box performance, I'd say not in your case, but I do recommend doing the bracing, both of them.
  • Who's Online   0 Members, 0 Anonymous, 4297 Guests (See full list)
