Which component is causing this...?
I have a subwoofer setup that consists of the following:
SUBWOOFER- 12" Power Acoustik Mofo 122-X (http://poweracoustik.com/store/products/subwoofers/mofo/mofo-122x.html)
BOX- T-Line Ported to 32hz
AMPLIFIER- Soundstream Picasso P1.1200d (http://soundstream.com/store/car-audio/amplifiers/picasso/p1-1200d.html)
I have noticed that on fairly low notes I can hear the bass coming from the subwoofer but don't feel it. My friend has a Rockford Fosgate P3 12" on a JL 300/4 (I'm 99% sure, I know it sounds odd) that actually hits those notes and you can feel it rattle your brain. Mine just seems to make the sound without the actual rumbling. I was curious what I am lacking in my system or what needs changed that will allow me to actually successfully hit those low notes without "bottoming out".
Thanks in advance!
Current Setup: 2002 Ford Focus SE (stock electrical)
-Kenwood Excelon KDC-X397
-Infinity Kappa 6x9's in each door
-Rockford Fosgate Prime R1200-1D
-2 12" Rockford Fosgate P3D2
Backups:
-12" Power Acoustik Mofo-122X in 36hz T-Line box
-Soundstream Piasso P1.1200D
Your box. T lines usually need much less power in order to reach a subs limits. Add in that you're playing under tuning and that can bottom out and now a sub
Also probably can't hear the frequencies anyways
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
So you're saying I should switch to a new box (such as a ported box) and that may prevent it from bottoming out so easy? Also, will switching to a ported box really add an increase in volume from the sub? Just curious and would like to know for personal information gain! ^_^
Backups:
Unless you both drive the same car with the same stuff in the trunk and the same fabric on the seats and have the same amount of occupants and have the trunk open/closed as your friend did you can't compare 2 things like that, there are too many variables at play.
Can you try your friends sub and box in your vehicle? If you still get that rumble you want out of your friends setup in your vehicle, than buy what your friend has.
I absolutely understand what you mean by proving that we don't have the same cars, etc. BUT, his is substantially louder. There is nearly no comparison it seems.
Backups:
Then just swap subs with ur buddy for a day. Test out his sub/box setup. If u like, then buy something similar and build a similar box. The tools to answer ur question are sitting right in front of you. Go test them out and report back.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
where is your subsonic set at? your amp and sub should be much louder then his. he's running a 4 channel amp... to a pos sub (imo,i bought two so i Can say that. i hate Them!) the mofo can get loud and hit low. i have a feeling you have something that's tuned a Lil off.
jvc deck
stinger 1800 front
hc 2000 kinetic rear
2 runs of 1/0g
big 3/4
ct 60.4
2 ct 1400.1
ct EXO 15 d1
lots of deadner
type r comps front stage
6 kicker tweets rear stage
lots of great stuff
coming soon
ho alt
more bats
ct comps for front stage
more deadner
sweet amp rack
lots of L.E.D lights
What's your sub wired to? Make sure it's wired to 1 ohm not 4?
'97 Explorer
2 Sundown SA 15's
SQ 2200D
Kinetik KHC1800 (Front)
Kinetik KHC 2000 (Back)
KnuKonceptz 1/0 OFC
130A Alt + Big 3
I know this sounds absolutely pathetic, but I got the sub off of Craigslist... and... I cannot figure out how to remove the subwoofer from the box. There doesn't appear to be any screws to unscrew or any removable panels to expose screws. Sorry for the absolute inconvenience, but I would like to learn more about what I have.
Also, I will upload pics of my system and gain opinions from those who have time to give them.
Backups:
Screws should be under the (black/blue) plastic trim around the sub if I recall.
'97 Explorer
2 Sundown SA 15's
SQ 2200D
KnuKonceptz 1/0 OFC
130A Alt + Big 3
  • Who's Online   1 Member, 0 Anonymous, 1653 Guests (See full list)
