So I just put in two new subs and a bigger box. I lifter up my trunk carpet to notice that were I screwed the ground to the chassis had rusted... Quite a lot. My question is should I just grind the rust off or just move the ground to a different area of the trunk? I believe where the ground is now water may splash up from the tires causing it to rust I'm not sure..
If that location rusted I sure as shit wouldn't use it again. Either way, grind off the rust/clean that shit up. Then find a new grounding point directly on the frame that will get less /no water on it.
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
Buy a tube of dielectric grease and apply over power connections that are prone to rust.
yes the grease!
images%2Farticle%2F2014%2F03%2F03%2Fku-x
  • Who's Online   0 Members, 0 Anonymous, 378 Guests (See full list)
