Syphlyn Posted August 19, 2014 Report Posted August 19, 2014 Hello, Got my system all ordered and am wondering about amp grounds. The green circle is where my 4 channel is grounded right underneath that plastic "step". Planning on grounding my Monoblock amp right behind it closer to the red circle. Are those good points to ground, the screw/bolt goes right through the metal underneath that plastic step and its sanded. My amps are right where the first gap is on that box under the seat. (THIS IS NOT MY TRUCK JUST A RANDOM F150 OFF GOOGLE) Edit: the metal running through the bottom left of the red circle continues and that's what it's grounded to. Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
dawgs007 Posted August 19, 2014 Report Posted August 19, 2014 I have 2 1200w amps grounded within 2 in. of eachother on a trunk latch. One ground per bolt. Haven't had a single problem with them being ground closely. Current Setup: 2002 Ford Focus SE (stock electrical) -Kenwood Excelon KDC-X397 -Infinity Kappa 6x9's in each door -Rockford Fosgate Prime R1200-1D -2 12" Rockford Fosgate P3D2 Backups: -12" Power Acoustik Mofo-122X in 36hz T-Line box -Soundstream Piasso P1.1200D
Syphlyn Posted August 19, 2014 Author Report Posted August 19, 2014 I have 2 1200w amps grounded within 2 in. of eachother on a trunk latch. One ground per bolt. Haven't had a single problem with them being ground closely. More concerned if the metal im grounding it to is a good place to ground it to. Syphlyns 2000 F150 4.6L V8 H/U: Kendwood KDC-X898 Speakers: 4 x Alpine SPR-68 Speakers 4 Channel Amp: Alpine PDX-F4 Sub: Sundown Zv4 12 Sub Amp: Sundown SAZ-2000D Box: 2.75 Cu Ft @ 31Hz Alternator: Mechman 250A elite series Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
reedal Posted August 19, 2014 Report Posted August 19, 2014 As long as it's bare metal chassis, it'll be a good ground. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
