H/o Alt, voltage drops
^doesnt always work, I ended up having the regulator swapped on my ho alt
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
I was thinking ELD.
Yea, it WILL hurt performance. Now, whether or not you notice performance loss.. That's a different story.
A buddy had a similar issue. When he got a GM reg installed, he noticed an audible difference.. And then gained on the meter (fuck the meter :) )
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I was thinking ELD.
Did they drive a Honda crv :peepwall:
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
Team DC Audio
With a TON of decals? Yes!
LMFAO so true
:blush:
Wow I didn't know about this, I'm still a pretty big noob. Does it hinder audio performance in any way? - the DC 3.5K is rated at 3500watts only when at 14.4V. Does this mean i Don't get full performance.
Tron do you get this voltage drops while you are driving and battery is charged?
Your vehicle probably has a PCM controlled regulator right? If so, that's pretty normal. It's the computer lowering the voltage because the battery doesn't need to be charged and thus decreasing the output of the alternator to increase fuel efficiency, not much but a little bit.
Happens on my truck all the time, starts up at 14.8 and drops as low as 12.8 if my batteries are fully charged up.
It happens when the batteries are charged up, and nothing other than the basic electrical components to run the vehicle are being used. As soon as I turn on the A/C, high beams, heated seats, or turn volume all the way up, the PCM senses the extra demands and bumps up the voltage.
These "smart" charging systems are pretty standard in newer vehicles, I'd say from 2007 and up.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Ok cool, as long as when i start to turn the audio up it will call for more more voltage. I have not hooked up my new sub yet so have been unable to test.
Front Mids/Tweeters: Focal K2 POWER
Rear Deck Mids: Focal 165ca
Subwoofer: (1) DC Level 5 15"
Highs/Mids Amp: Mosconi Gladen One 120.4
Monoblock: DC 3.5K
Headunit: Kenwood Excelon DNN990HD
Batteries: Optima Yellow Top (hood), Kinetik HC600 (trunk), XS Power D3100 (trunk)
Car: Accord '08 Coupe... terrible trunk shape : ' (
  • 3 weeks later...
I drive a 2013 Camry and experience this issue as well. Welcome to Japanese cars. Regulated voltage BS. I have a Mechman 240amp and in the winter when I start my vehicle up, I will see 14.4 on occasion. In the summer here in Houston, my typical idle voltage is 13.4. Rev engine and can get to 13.7. Drive on freeway 70mph and I run around 13.9. My voltage bounces around everywhere, so what you're experiencing isn't uncommon. You should really try to buy another belt that is a 1/16" smaller than your factory belt, as the MechMan pulley is smaller and you could be experiencing belt slip as well. Do you see any black powdery residue on and around the housing of the alt?
Also, others may disagree with this statement but the way I see it is like this. I average 13.6v on a typical day. If I start seeing my voltage drop to 12.0v full tilt, then it's time to start charging my batt's. If you voltage starts hitting mid 11's, time to start throwing more batt's at it and stabilize your voltage a little more. I really try to stay above 12.2v on LOOONG bass drops. If I go below, then I do what I listed above.
Honestly, I wouldn't worry about it too much, as you really can't hear the difference in 1 volt. Now, if you're metering, it may mean a few tenths. I would make sure you have a decent battery bank to support the regulated voltage and keep that bank charged. Also, check your belt. If you can get a tighter belt on it, do it. It's a cheap fix...
Good luck man...
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
  • Who's Online   0 Members, 0 Anonymous, 1105 Guests (See full list)
