Orfeous Posted August 24, 2014 Report Posted August 24, 2014 Trying to calculate and design a box for a Rockford Fosgate T2D212 and i want the box tuned to about 36Hzand a box volume of 40 liters. But the problem is that the port length is going crazy for that. Using 4" port Optimized for deep bass Suggestions? I know that making a slotport can solve the problem but.. i like those aero ports..
Orfeous Posted August 24, 2014 Author Report Posted August 24, 2014 Volvo S40 2006~1200RMS@1ohm (P1000x1)
TRON Posted August 24, 2014 Report Posted August 24, 2014 You're not even close to the minimum recommended ported volume. 40l = 1.41cuft, minimum recommended from Fosgate is 1.75cuft, max is 2.25. You'll want more volume to get deeper bass, so do 2.25 cuft. or 63l in your case. If you use one round port, at 4'' diameter and assuming it will be a flared areoport, it has to be 24.6 cm long. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
Orfeous Posted August 24, 2014 Author Report Posted August 24, 2014 Yeah, i know.. that the box needs to have a lot of more volume.. but.Got a friend that is helping me with this and this is what he was calculating.. But as you say.. i agree 40l is too small. Recommended vented is ~50l but tuned to 40Hz Why is the recommended tuned to 40Hz and box tune in general is like 32-36Hz Problem is to fit it in my trunk also
TRON Posted August 24, 2014 Report Posted August 24, 2014 2.25 cuft isn't very big, should fit in the back of your car no problem. Not sure why there would be a recommended tuning, but you can tune it to whatever you damn please. EDIT: Rough dimensions for 60l would be 28 x 68 x 45 cm. Avalanche Alpine Type S comps Alpine Type S 10'' Alpine MPR-F300 Alpine MRX-M50 Mechamn 270 XS Power d3400s
Joe X Posted August 24, 2014 Report Posted August 24, 2014 A single 4" wont work, instead 3 3" is what RF recommends. So here's something to work with if you really want round ports, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 3": NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
Orfeous Posted August 24, 2014 Author Report Posted August 24, 2014 Ok, i really appreciates your suggestions but i feel kinda lost One tells me 4" port is ok, one tells me it isnt... one tells me 3" port must be used.. A 4" port is used for a box for T1D212 why didnt rockford use that for T2D212 also?
Joe X Posted August 24, 2014 Report Posted August 24, 2014 Don't take my word for it and check your sub's manual.
Guest Posted August 24, 2014 Report Posted August 24, 2014 the bigger (in size, not length) for circle ports, the less chance for port noise like you're having. but too big and the sub wont play well. edit: two 3" ports is more port than 1 4" port.
