dolarbilz Posted November 12, 2014 Report Posted November 12, 2014 I hate wrapping...I would rather sand smooth and paints..days work..
moredbs Posted November 12, 2014 Author Report Posted November 12, 2014 I hate wrapping...I would rather sand smooth and paints..days work.. I'm hoping wrapping won't be so bad with the right vinyl.if i painted i would have to do a lot of work cause these things are covered in glue. maybe some texture paint,but i don't want it to look tacky.
dolarbilz Posted November 12, 2014 Report Posted November 12, 2014 Glue not to bad get off.as long you have a air diegrinder. If you change your mind on painting..use Sem products.gives it the best look out of a can..
moredbs Posted November 18, 2014 Author Report Posted November 18, 2014 i went ahead and installed the pods,wanted to hear them,and make sure everything was working.
moredbs Posted November 18, 2014 Author Report Posted November 18, 2014 you cant tell in these pics,but the pods are a little off. i will probably rework them with some body filler when winter is over.
moredbs Posted November 18, 2014 Author Report Posted November 18, 2014 Got them in and playing,and ran into a problem with the amp.I get engine noise when i hooked up 4 rca ,i don't get it when i only run 1 set.i read a thread awhile ago about some of crescendo amps having noise issues. Guess ill have to contact them and send it back. i will say that i am happy with the way it sounds on the 2 channels,its much better than what i had before.
magillaru Posted November 18, 2014 Report Posted November 18, 2014 Are you using a relay? Singer Alternators Team Asshole #anothershittysingerbuild
moredbs Posted November 18, 2014 Author Report Posted November 18, 2014 Are you using a relay? no relay, just read some other threads with the same issues with whining,but none got answered. im gonna try and send it back
magillaru Posted November 18, 2014 Report Posted November 18, 2014 I've never ran multiple amps so I don't have any first-hand experience but from what I've read, a relay should be used with multiple amps and also the type of RCAs you're using can make a difference (twisted vs coaxial).......just a thought and maybe something to look into btw, the doors are lookin' good! Singer Alternators Team Asshole #anothershittysingerbuild
moredbs Posted November 18, 2014 Author Report Posted November 18, 2014 ^thanks, i got a spare pair of twisted won't hurt to try.
