Karkov Posted December 29, 2014 Report Posted December 29, 2014 Chasing down the list of things to do is always a good feeling. getting it done is another thing, lol, jk, nice to see you getting some small progress going on man. Always tuned in for more, and.....NICE purchase!! 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
DylanBunch Posted December 29, 2014 Report Posted December 29, 2014 My friends dc 5k is mounted on his wall and it rattles bad too, the screws on the back piece get rattled loose, probably the same with a lot of amps. I just wouldn't mount it on your box if you can avoid it 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
moredbs Posted December 29, 2014 Author Report Posted December 29, 2014 My friends dc 5k is mounted on his wall and it rattles bad too, the screws on the back piece get rattled loose, probably the same with a lot of amps. I just wouldn't mount it on your box if you can avoid it thanks for the info! I'm very limited in the space i have left.i just thought maybe if i put some 2 by 4s on the back of the box it would help with vibration,and flex.i want to also put 2 by 4s on the top of the box as well,not sure if its flexing there,but i feel like this box design is a little weak.
Miguels Posted December 29, 2014 Report Posted December 29, 2014 nice amp.. does it match your 9k amp? my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Miguels Posted December 29, 2014 Report Posted December 29, 2014 screws shouldn't get loose.. if they did then why dont subs get lose.. adding 2x4 will help with flex. just use better screws. the thickness of the wood wont let the screws get lose my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
moredbs Posted December 29, 2014 Author Report Posted December 29, 2014 nice amp.. does it match your 9k amp? no its the new model with the stripes. the 9k is older model.
moredbs Posted December 29, 2014 Author Report Posted December 29, 2014 screws shouldn't get loose.. if they did then why dont subs get lose.. adding 2x4 will help with flex. just use better screws. the thickness of the wood wont let the screws get lose i used smaller screws to mount the 9k,and one of them was a little loose.it just feels like i need to make everything more strong and sealed up better in this build,to get more out of it,and to have peace of mind.
Miguels Posted December 29, 2014 Report Posted December 29, 2014 i used 1 1/2 long screws on my amp and they havent worked their way loose.. longer screws should work and use spax the only way i see the screws going loose is if you have the fine thread and using mdf.. you need coarse thread http://www.spax.us/en/mdf-hardwood-screws.html#.VKDtPF4CA my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
DylanBunch Posted December 29, 2014 Report Posted December 29, 2014 I'm talking about the screws on the back of that amp that hold the back piece of the amp on that covers the board. Not amp mounting screws 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows
moredbs Posted December 29, 2014 Author Report Posted December 29, 2014 I'm talking about the screws on the back of that amp that hold the back piece of the amp on that covers the board. Not amp mounting screws yep, thats probably were its coming from.Is elevated about an inch,so the fan can breath,and stops when i put my hand under there. I thought mounting amps,and vibrations was a myth? maybe i read it wrong.
