pimpedout97x Posted May 22, 2008 Author Report Posted May 22, 2008 not glued in yet, just wanted to see what it all looked like. not as many gaps as i thought. glassing it all soon and itll be perfect
Guest Nismofreak Posted May 22, 2008 Report Posted May 22, 2008 i would take em off if I where you and just install the plywood piece on the door. The mini cooper panels ain't cheap. Thats for sure
pimpedout97x Posted May 22, 2008 Author Report Posted May 22, 2008 i dont want to do that. the wood doesnt fit against the bare door perfect, so the edges will look like crap. i want the factory panel touching the door. car will never be returned to stock, so who cares.
pimpedout97x Posted May 28, 2008 Author Report Posted May 28, 2008 port is officially liquid nailed, tite bond 2'd, and screwed in. its not coming out ever went a little crazy on the foam, how i screwed the top of the port to the roof, from inside the port. was a BITCH
BigPimpin91 Posted May 28, 2008 Report Posted May 28, 2008 Enuff Chit Chat GET BACK TO WORK! BigPimpin91's Banging Music
pimpedout97x Posted May 30, 2008 Author Report Posted May 30, 2008 ok people did a little bit today tomorow im gonna glass the entire rest of the box, but i wanted to get it glassed up in the corners first, let it harden (which is hard as a rock now) then tomorow ill put a 2nd layer over that while i coat the rest of the box. foamed it up first then taped it up. i used a special anti-Darrell solution. this is an inside joke between me and robin, about a fat dude that works at my job (robin used to work there) and finally, glassed
suburban ant Posted May 30, 2008 Report Posted May 30, 2008 mmm glass - Infiniti QX4 - - 2 Digital Designs 9917s - - Digital Designs Z1 - - Digital Designs C3b -
ptcary Posted May 30, 2008 Report Posted May 30, 2008 Looking good! Man you really used all the available space back there in that car! PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
pimpedout97x Posted May 30, 2008 Author Report Posted May 30, 2008 thanks i just put the baffle on and braced the bottom of the port and the sub baffle with 2 2x4s.
