ChevyBoy Posted September 22, 2008 Report Posted September 22, 2008 Tech Tip, Get you some Blue or Red Loc-Tight and every screw, bolt and nut in the door take them out put some Loc-Tight on them and put them back in. I guarantee they will stay put. Start with the blue if they back out or loosen up with that on them, Then switch to the red. That will help you out big time! Hope that helps you out. To all you guys Remember Loc-Tight is your friend! Shannon Oh, One more thing! Kick @ss Mini man. But I can't believe you did that to the car. CRAZY! do NOT put red loctite on there. if you ever need to get something out, youre fucked.
ImLow78 Posted September 22, 2008 Report Posted September 22, 2008 do NOT put red loctite on there. if you ever need to get something out, youre fucked. That would be the last resort. But you can get still take bolt and screws loose with red loctite on them, we do it all the time all you have to do is put heat to it and it will loosen the loctite back to a liquid form. we use Red loctite when we install fogger nozzles in aluminum intakes and when we take them out we use a small butane torch and they come right out. But I agree that should be a last resort but the blue should work just fine. Shannon 2004 Tahoe.Equipment Kenwood DNX7100 Kenwood Bluetooth adapterKenwood iPod interface cableAudiocontrol DQXSAlpine PDX 4.150Rockford Fosgate punch 40DMS Diamond Audio D363.5 (6.5" Components) Front DoorsDiamond Audio D363.5 (6.5" Components) Rear DoorsJL Audio 15w0's Subs In a 8cu. ft. Box.Monster cable XLN PRO RCA'sMonster Cable 16ga speaker wireMonster Cable 1/0,4ga power, Ground cable.I only got this Monster Cable stuff because I got it dirt cheap. (Crack Head Prices)
ChevyBoy Posted September 22, 2008 Report Posted September 22, 2008 i dont know about you, but im not taking a torch to my door panel
pimpedout97x Posted September 28, 2008 Author Report Posted September 28, 2008 started with this. the trim panel isnt on in this pic yet. foam ftw. sun was out, but the best shot i could get of the underside of the box pics of the trim panel installed later..my sister took the camera.
pimpedout97x Posted September 28, 2008 Author Report Posted September 28, 2008 the other half of the beauty panel is cut, but i just gotta router out the hole and round it off. ill bondo the cut in the middle of the subs before its covered in padding THEN vinyl (also will fill all screw holes) ill do that tomorow. i like how its coming out though.
pimpedout97x Posted September 28, 2008 Author Report Posted September 28, 2008 this wire is the only access to my trunk. the power lock mechanism broke (ok, i broke it) so i use the manual release and i didnt have anything to extend it at the moment, so i used speaker wire, and when i permantly put the floor of this wall in, i forgot to extend it with something other than wire. its also tied on there in a double knot. if it ever comes undone, ill be pulling a steve meade and breaking my rear window with an 18" sub) the sub is only in my 2 screws, so yes, the gasket on the sub fits in the flush mount fine, its a tight fit but it fits.
Stephen Posted September 28, 2008 Report Posted September 28, 2008 pop hatch with the wire, tape something stronger to the wire then pull it into the front. cut wire off you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
pimpedout97x Posted September 28, 2008 Author Report Posted September 28, 2008 the wire is hooked to the factory emergency release cable, located here, which as you can see, my box completely covers over. lol
