BigHOUSTON Posted August 27, 2014 Report Posted August 27, 2014 Ok so this has me feeling dumb, but the situation is all the amps i've ever had have just one positive and one negative hook up for the speakers. Now I have this amp( MONO BLOCK) and it has two positives and two negative. If you are looking at the amp for the speakers its + ,+ , -, - . I've got two dual 4 subs and they are wired in parallel to achieve a 1 ohm load, now i've been thrown this curve ball. I sure its simpler than im making it out to be but input would be greatly appreciated
finkster Posted August 27, 2014 Report Posted August 27, 2014 The inputs are wired in parallel inside the amp. So just put the positive on one of the positives and negative on one of the negatives. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
BigHOUSTON Posted August 27, 2014 Author Report Posted August 27, 2014 The inputs are wired in parallel inside the amp. So just put the positive on one of the positives and negative on one of the negatives. So by doing that it wont change the ohm that im currently trying to achieve
Jhunt94 Posted August 27, 2014 Report Posted August 27, 2014 If you have the subs wired in parallel and just have one set of wires going to the amp it won't change anything. You could actually run leads from each speaker to each set of terminals and achieve a 1 ohm load because of the amp being paralleled internally. 2007 Ford F-150 Reg. Cab. Flareside250 Mechman AlternatorSky High Car Audio Big 3 XS Power D3400Rockford Fosgate 1/0 amp kitRockford Fosgate T1500-1bdcpRockford Fosgate T400-4DC Audio Lvl 4 12"Rockford Fosgate Punch 6.5" componentRockford Fosgate Punch 6x8Pioneer AVH-P2300DVDSMD Volt Meter
BigHOUSTON Posted August 27, 2014 Author Report Posted August 27, 2014 ok does it matter which positive and negative i run it to them?
MrSkippyJ Posted August 27, 2014 Report Posted August 27, 2014 Nope. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
