Isn't it already loose?
If not then you will want to carefully pull down on the unit from back to front
yes its loose, but its not like on the verge of falling off, just pretty lose..ill look at it and see what i can do, i dont really wanna break it/more , i hope the tape helps a bit, cause i dont want to really screw it as of now, lol
im lovin these subs tho, didnt u say if i start breakin stuff it means im a lil loud... :)
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
You should come up to reno on saturday and do some testing at the competition this weekend.
banner2.jpghttp://www.DCSOUNDLAB.com/01 Chevy Silverado X-CabPioneer 4900 in Dash3 Stinger 2150'sIraggi 260 amp Alt.1/0 Stinger Wiring(2) DC lvl 5 18's(2) Hifonics Cyclops10 cu box tuned to 27hz
not yet, 1st show i will be hitting is the one in anderson on the 26th and bill better be there lol
but 1 reno is a ways away, and 2 i dont have my proper amp yet.........need to get the pa5500 and power these bad boys right
My F-150 Build
In my astro I have this same problem. What we did is use toggle bolts ( http://images.builderssquare.com/Detail/0/...5589_Detail.jpg ) , in place were the normal screws were, then used Teflon tape and a nut to stop everything from moving. Works pretty well, sometimes they need to be tighten because of the flex on the roof, but it was a pretty easy fix, and we just used the existing screw holes that were already there.
Hope this helps
Edited by NotoriouslyLoud
Hope this helps
ill look into that, but have a non bird link, lol
that link was all about birds..;)
My F-150 Build
Hope this helps
can i get shorter ones? and when i tighted the screw is it like a nut and bolt type deal? also how well will that hold it up...when i tape it too
My F-150 Build
