VS Statesman Trunk Build
keep an eye on that adapter wiring harness too, I've seen a lot of those fail and cause issues..... I had no dramas with my deck in the stato.... although it did take a lot of time to get all the rca's and wiring tucked away so that the deck would slide into position snugly.
What fails on the harness? Ive never heard about anything like that.
1998 Holden VS Statesman
Kenwood KDC-U556BT
Cadence CS2.65K
Pioneer GM-D9601
Alpine SWS-10D4
KnuKonceptz 0 Gauge
Response 4 Gauge
Execution Audio 60.4
the little pins become loose inside the plug... have seen one of the pins come off completely inside the plug. I use male and female crimp connectors. (not all of them adapters fail, just a few I have seen have failed) so if you loose output to one of your speakers or deck stops turning on, check that first imo
  • 2 months later...
Little update
Making pods for the rear door for mids as theres no speakers in them
So much sanding to do :(
Kenwood KDC-U556BT
Cadence CS2.65K
Pioneer GM-D9601
Alpine SWS-10D4
KnuKonceptz 0 Gauge
Response 4 Gauge
Looking good man. Im loving the neon green tech flex :good: looking forward to seeing the numbers on that new box.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Top one is what the sanding band is supposed to look like and the one below it is what happened after i heard a pop while sanding.
And now im wearing safety glasses lol.
And a little something i may add to the box.
Kenwood KDC-U556BT
Cadence CS2.65K
Pioneer GM-D9601
Alpine SWS-10D4
KnuKonceptz 0 Gauge
Response 4 Gauge
Small update i have finished the speaker rings.
How thick it is :(
Ready for fiberglassing (once i get some resin)
Kenwood KDC-U556BT
Cadence CS2.65K
Pioneer GM-D9601
Alpine SWS-10D4
KnuKonceptz 0 Gauge
Response 4 Gauge
  • 3 weeks later...
Little update
Added some aluminium tape to the boot holes.
Kenwood KDC-U556BT
Cadence CS2.65K
Pioneer GM-D9601
Alpine SWS-10D4
KnuKonceptz 0 Gauge
Response 4 Gauge
  • 1 month later...
Quick update
I'm turning the box so that the subs face the back.
Added some aluminium tape to the boot floor to cover the holes and because i felt like using it hahaha
The lonely wires in the boot :(
Thought i would open up the 4 Channel to see inside, It weighs about the same or a little bit heavier than the monoblock
This is the MDF where ill be mounting the amps instead of on the box like it used to be
Kenwood KDC-U556BT
Cadence CS2.65K
Pioneer GM-D9601
Alpine SWS-10D4
KnuKonceptz 0 Gauge
Response 4 Gauge
Quick update
Holes cut for the wires and rca's
Some carpet
And i cut my finger :(
A bit late but i picked this up tonight :D
And these
And ill be metering the car on the 29th
Kenwood KDC-U556BT
Cadence CS2.65K
Pioneer GM-D9601
Alpine SWS-10D4
KnuKonceptz 0 Gauge
Response 4 Gauge
Update
Cut some holes to keep the amp cool (not that they heat up anyway)
The amp rack in its place all hooked up
Subs facing back finally and ignore the upside down subs haha
21 Days till it gets metered :D
Kenwood KDC-U556BT
Cadence CS2.65K
Pioneer GM-D9601
Alpine SWS-10D4
KnuKonceptz 0 Gauge
Response 4 Gauge
