Voltage problem?
Just finished install the other day big 3 done xs d3400 under hood and a worker g31 in trunk and voltage on idle is 13.3 any ideas ? Only around 1000 rms pushing it right now
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
is that 13.3 ur charging voltage Caleb? Whats the voltage on the alts pos stud.
I want you to do this with the DMM.. Set it to DCV.. Pos probe on alt +, neg probe on alt gnd or alt case.. All with the car on.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
13.96 at alt
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Is the g31 at 13.3? My guess is loose/corroded batt terminals or fuse holder bolts.
LMFAO so true
:blush:
Everything is new in it no corrosion or lose wires voltmeter is reading 13.9 currently but throughout the day is changes up just thought is should be around 14+
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Where is that 13.3 reading cumming from?
LMFAO so true
:blush:
13.3 coming from mid day at idle with car on just thought it would be in the 14's after the big 3 and adding a extra batt but guess I'm wrong lol
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Batts don't add voltage.. Just helps hold it.. Well under rest.
Big 3 doesn't necessarily increase voltage either.. Just improves the charging current flow.
LMFAO so true
:blush:
  • Who's Online   0 Members, 0 Anonymous, 2733 Guests (See full list)
