littleitaly1990 Posted March 27, 2008 Report Posted March 27, 2008 oh my, what to do??? :mad: A vitrolic, megalomaniacal sadistic psychopath.
Stephen Posted March 27, 2008 Report Posted March 27, 2008 oh my, what to do??? :mad: EA's have a 6 month warranty you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
mrwigglezdj Posted March 27, 2008 Report Posted March 27, 2008 check the belt, sounds like youre sliping, or your alt can be torqued a little causeing it to be off axis thus the sliping of the belt and noise and loss of charge Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
littleitaly1990 Posted March 27, 2008 Author Report Posted March 27, 2008 I emailed Nate and will hopefully get an E-mail back tomorrow...it's not the belt, when I spin the alts pulley it makes a very faint high pitched noise. A vitrolic, megalomaniacal sadistic psychopath.
Stephen Posted March 27, 2008 Report Posted March 27, 2008 I emailed Nate and will hopefully get an E-mail back tomorrow...it's not the belt, when I spin the alts pulley it makes a very faint high pitched noise. i swear mine said 1 year warranty and last time i called him he is telling me 6 months :mad: you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
mrwigglezdj Posted March 27, 2008 Report Posted March 27, 2008 either the front bearing or the rear rotor bearing is the problem then, easy fix if its the case (for nate its easy) unless you have a good alt repair shop that can sell you new bearings and youre good with a paper clip lol to align the brushes have nate do it lol... Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
littleitaly1990 Posted March 27, 2008 Author Report Posted March 27, 2008 either the front bearing or the rear rotor bearing is the problem then, easy fix if its the case (for nate its easy) unless you have a good alt repair shop that can sell you new bearings and youre good with a paper clip lol to align the brushes have nate do it lol... Nate=warranty...I'll stick to him! A vitrolic, megalomaniacal sadistic psychopath.
PaulO2288 Posted March 27, 2008 Report Posted March 27, 2008 either the front bearing or the rear rotor bearing is the problem then, easy fix if its the case (for nate its easy) unless you have a good alt repair shop that can sell you new bearings and youre good with a paper clip lol to align the brushes have nate do it lol... Yeah thats what happened to my sisters Tahoe. It was the bearings.
littleitaly1990 Posted April 1, 2008 Author Report Posted April 1, 2008 This is the EA alt... The left side obviously has a lot of black from my belt....I think it was locking up. Now I have a real problem (not bad, but real) Although my old alt is quieter than the last one, it is squeaking and not charging as well. And today out of the blue while on the highway my voltage meter just went kaput and the "check gauges" light went on...I turned it off and on and it was fine...weird...but I have a feeling my idler or tensioner pulley are involved...I don't know, but I paid off a lot of dept, got a tux for prom, and now I'm gonna throw a ton in to get my Jeep working properly and replace a burnt crossover... Whatever...Pe@ce A vitrolic, megalomaniacal sadistic psychopath.
