ModestDb Posted September 15, 2014 Author Report Posted September 15, 2014 Found it on Amazon for $7.30 I'll hold out for another 24 hours before ordering it. Just in case anyone here comes through with other ideas or things to try first. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
SIDE SHOW Posted September 15, 2014 Report Posted September 15, 2014 some units have aux 1 and 2, 1 = pbus and 2 = 3.5in..... if your gonna get the p-bus adapter might be worth looking at the Bluetooth/ipod/usb interfaces that also can use the pbuz (at the same time)
ModestDb Posted September 15, 2014 Author Report Posted September 15, 2014 Side Show, I just checked and I only have the option for Aux on/off. No choice to select an Aux 2 at all. I just read the crutchfield details from where this cd player was purchased several years ago. It says it has an option to expand to using aux input but a separate cable had to be purchased. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
SIDE SHOW Posted September 15, 2014 Report Posted September 15, 2014 cdib10 = give you left and right audio input through the p-bus connection, cdib20 does the same but has another pbus port
SIDE SHOW Posted September 15, 2014 Report Posted September 15, 2014 also try turn the aux on and then turn the volume up on your phone with it plugged in, then press source until AUX come up on the screen. then turn the headunit volume up. and vola. it works
ModestDb Posted September 15, 2014 Author Report Posted September 15, 2014 I tried aux on, and volume maxed on my phone and almost maxed on my deck. I got nothing. 4 American Bass VFL 8" at 0.5 ohm Soundstream Tarantula 3000.1D at 0.5 ohm 32 hz ported box designed by Mark at Car Audio Fabrications XS D1200 secondary with Stinger isolator
SIDE SHOW Posted September 15, 2014 Report Posted September 15, 2014 Did you change to cd player source to AUX? then turn it up?
SIDE SHOW Posted September 15, 2014 Report Posted September 15, 2014 should go tuner, cd, aux I think
