What do I set my crossover at?
Can you HP any higher than 600 or LP any lower than 600?
What about your headunit, what type of eq adjustments does it have on it?
Yes, I can set the filters anywhere, you can see the adjustments in the pic of the crossover in the second post.
The head unit does have a parametric eq, but no crossover functions.
Well assuming you will have peak if both are set to 600, you have a couple options. Either separate the crossover freqs (for example, HP at 750 and LP at 600 to start) or lower the 600hz range using the headunits eq.
The frequencies I listed are just for reference, you will have to play with it. And again, thats assuming there is enough of a peak there to be noticed.
SMD Super Seller
My Feedback Thread
You will have better luck with the midbass driver away from the midrange drivers ... Especially if you plan to have a pair of midrange drivers per door.
That way you could start out full range with the mid bass drivers and tune from there and not a generic setting.
My only real option is the doors. The handicapped conversion rules out the kicks. The drivers will all be in separate enclosures.
Put them in the rear quarter panels like the award winning GN ...
In all essence ... If you have that much midrange (which I like alot), your tweeters really need more separation too if you have the tuning capabilities. Like up and out on your dash / a-pillar area ...
  • Who's Online   0 Members, 0 Anonymous, 1273 Guests (See full list)
