krazz619 Posted September 21, 2014 Report Posted September 21, 2014 Hey guys, need help figuring out what battery to power my system that should be arriving soon. I drive a 2001 Toyota Corolla but I want someone power enough as a starting battery/600 watt system. Also to be able to reuse the battery in my next vehicle? Any ideas please Was originally gonna get a XS XP750 but they're sold out at Sonic Electronix. Any other options? (Preferably cheaper lol) I looked at Shuriken SK-BT35 and SK-BT20, Kinetic HC600-BLU/800-BLU, taking recommendations or opinions on listed batteries. Thanks in advanced Edit: **Also, if someone can recommend a decent voltage meter gauge I can put somewhere on my dash to watch my battery. 2015 Scion tC DieHard AGM Battery, Stock Alternator, with Big 3 Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials Rockford Fosgate T2D215 Skar RP-1500.1D and RP-150.4AB
SLYentist Posted September 21, 2014 Report Posted September 21, 2014 check out XS' application guide @ http://4xspower.com A lot of time the BCI size recommendation given there can be used with any AGM battery make if the XS part is out of stock. Cables and wires almost never fail; the terminations do.
krazz619 Posted September 21, 2014 Author Report Posted September 21, 2014 check out XS' application guide @ http://4xspower.com A lot of time the BCI size recommendation given there can be used with any AGM battery make if the XS part is out of stock. That's not what I'm really looking for, I just wanna know good battery to use as a starting battery and for a 600 watt system, whether it is XS Power or not 2015 Scion tC DieHard AGM Battery, Stock Alternator, with Big 3 Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials Rockford Fosgate T2D215 Skar RP-1500.1D and RP-150.4AB
reedal Posted September 21, 2014 Report Posted September 21, 2014 check out XS' application guide @ http://4xspower.com A lot of time the BCI size recommendation given there can be used with any AGM battery make if the XS part is out of stock. That's not what I'm really looking for, I just wanna know good battery to use as a starting battery and for a 600 watt system, whether it is XS Power or not That's exactly what you're looking for actually. As he stated, the BCI group is what you need to go by. XS just makes it easier for you to figure out what size. If you still disagree, then grab a tape measure, measure where your battery sits, and find the biggest agm you can fit. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
krazz619 Posted September 22, 2014 Author Report Posted September 22, 2014 check out XS' application guide @ http://4xspower.com A lot of time the BCI size recommendation given there can be used with any AGM battery make if the XS part is out of stock. That's not what I'm really looking for, I just wanna know good battery to use as a starting battery and for a 600 watt system, whether it is XS Power or not That's exactly what you're looking for actually. As he stated, the BCI group is what you need to go by. XS just makes it easier for you to figure out what size. If you still disagree, then grab a tape measure, measure where your battery sits, and find the biggest agm you can fit. I understand the BCI, my question though is, battery recommendations for my car and system, I'm not worried on battery size, I'll make a bracket or buy one for it. Just want a decent battery for both things wether it's made for my car or not. And the last part of your reply says that, "find the biggest AGM battery", that's what I'm here for, is to get help on finding a good one. 2015 Scion tC DieHard AGM Battery, Stock Alternator, with Big 3 Alpine CDA-105, Hertz Energy 6.5" 3 Way Components, Skar TX65 Coaxials Rockford Fosgate T2D215 Skar RP-1500.1D and RP-150.4AB
reedal Posted September 22, 2014 Report Posted September 22, 2014 http://www.stevemeadedesigns.com/board/topic/69019-xs-power-battery-wattage-guide/#entry957120 Easy search on this forum. That's for XS batteries. Probably about the same results for other AGM's. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
