i realize it is 1ohm stable.... im kinda new to the car audio scene but i ran accross something about box rise? can someone explain? because i want to go with a dual 2 18Q or 2 15"ssd's dual 1's wired to 1 ohm and that means that the amp will see a .7ohm load and i dont want to blow my amp
1 Fi Sp4 18
Crescendo 2k
selenium mids
audioque supertweets
Hifonics for mids and and highs
1/0 power and grounds
---> on the way singer alt and possibly another
2k depending how sub likes 1 2k
It'll be .75ohm technically, but as long as you have them in a good box your overall impedance will be close enough to 1ohm so your amp will be fine.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
You will have to do dual 2 ohm woofers if youre getting 2 to get a 1 ohm load. Not dual 1 ohm
If youre going to do a single woofer do a dual 2 ohm and it will wire to a 1 ohm load.
Edited by mtxcivic07
18's in a wall to come....Its not all about the posts....check the member #...
Not true. you can't get a 1 ohm load from 2 dual 2ohm subs.
Although if you really wanna play it safe, get the dual 2 ohm versions, then you can wire them to a 1.5 ohm load since they're FI's. You'll be fine either way really
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
wow. my bad i didn't mean to type that
I meant...
(1) dual 2 ohm woofer will wire to 1 ohm
(2) dual 2 ohm woofers will wire to .5 and 2 ohms
(1) dual 1 ohm woofer will wire to 2 ohms
hope thats easier to read.
Box rise wont make it 1.5 though...
and 2 dual 4 ohm subs can be wired to 1 or 4 ohm to the amp
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
FI doesn't sell dual 4's, but good addition.
wait i thought 2 dual 1 subs could be wired to 1 ohm (.75 For FI's) by wiring each sub in a series that would be a 2ohm load then wiring the two subs together parallel that would be a 1ohm load right
Edited by jayjay6888
1 Fi Sp4 18
Crescendo 2k
selenium mids
yes.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
yes.
thank you nice clean simple reply
1 Fi Sp4 18
Crescendo 2k
selenium mids
