BoomZoom808 Posted September 26, 2014 Report Posted September 26, 2014 Picked up a pair for cheap and wanted to mess around with them. Going to be in my Mazda 3 trunk car on 1K to the pair. Can someone help me design an enclosure? 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
BoomZoom808 Posted September 26, 2014 Author Report Posted September 26, 2014 and yes I already tried to search for 1 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
Joe X Posted September 27, 2014 Report Posted September 27, 2014 So here is a suggestion, check suggested dimensions before anything, firing everything back, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide:NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
RainStryke Posted September 27, 2014 Report Posted September 27, 2014 Looks like a good box you were recommended. Alpine recommends .75 to 1.3FT^3 per sub and for the port to be tuned to 32-37Hz. So that box should do perfect. Recommended sealed box would just be 1.7FT^3
BoomZoom808 Posted September 29, 2014 Author Report Posted September 29, 2014 So here is a suggestion, check suggested dimensions before anything, firing everything back, power: to sub(s) rated, amp subsonic filter to 28Hz, minimum port clearance 3 1/2", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Thanks Joe X always coming through! The last box you helped me on for a SQ 15 I ended up taking your suggestion and switching to a T1 15 and couldn't be happier. 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
