dedicated starting battery
ok so new plan then. does anyone have a recommendation on a battery charger/maintainer that i can wire into my block heater wiring and plug that in over the winter? say a 2-5A charger? for AGM
nothing, gutted
best i can tell is my radio is pulling almost dead on what my alt is producing (or slightly under) and thus the alt is not able to keep the batteries up over my short drives. i suppose maybe a 2nd alt is in order. i really thought a single 380A mechman would be able to handle a 3 way setup and one sub.
nothing, gutted
Alternators are not immediate power. It takes a moment (a lifetime in electronics time) for the regulator to notice to voltage drop, then kick in to keep the voltage up. A little light dim is expected even with a rock solid alternator setup, this is where having an oversized battery bank helps. I see you have a beefy bank, so maybe the voltage is ECU controlled?
Cables and wires almost never fail; the terminations do.
You're onto something here.
:good:
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Ever think about completely isolating your car audio system? By running 2 alts. One attached to the starting battery and all stock electronics and the other alt on your agm batteries that power your sound system?
  • Who's Online   0 Members, 0 Anonymous, 7073 Guests (See full list)
