MB Quart OA2050.1D
Uriahia
Has anyone had experience with the MB Quart OA2050.1D?
Here are the Specs:
MB Quart OA2050.1D 2000 RMS Power Handling:
4 Ohm: 650 Watts RMS x 1 Channel
2 Ohm: 1300 Watts RMS x 1 Channel
1 Ohm: 2000 Watts RMS x 1 Channel
Q-Stasis Pre Amplifier
Stage FLUID-FETS
Class Q1
Variable Bass Boost (0 to +9 dB bass boost)
Protection circuitry (thermal, overload, and speaker short protection, dc)
MOSFET Power Supply THD at Rated RMS: 0.10%
Low-Pass Filter Frequency 40 -300 Hz
Variable Subsonic Filter: 10-40 Hz
Signal-to-Noise Ratio 95 dB
I personally have no experience with MB Quart but I've heard that they have good products.
What is drawing you to this particular amp, 2k at 1ohm? It's a Maxxsonics product, and not the flagship line from MB Quart. I would bet it doesn't do rated, especially if your electrical isn't up to par, and is power hungry like Hifonics amps. You could get something much better used, for the same price. You might be happy with it, might not.
Sadly, I have to agree with csermonet47^. I have a Hifonics BRZ1700.1D, by MaxxSonics. It needs a lot of power to do rated and even with a pretty hefty electrical system, does maybe 900W RMS out of the 1700 MaxxSonics boasts. I will put it this way, it barely moves my 1000W RMS PB 3XL 15 and that's @1ohm. I am pretty sure MBQuart uses a lot of the same electrical, boards, etc. as Hifonics, as they are both made by the same manufacturer. What is your price range? There are a lot of much better amps with much better efficiency out there, for a similar price. You can grab a Lanzar OPTI2000D for $246 shipped. .5ohm stable, will do an easy 2000 RMS @1ohm, that's what I am upgrading to when I get my second 15 here soon.
Head Unit - Clarion VX709 7" DVD Touchscreen
Mid/Highs - Front Doors - RF Prime 6.5" component mids.
A. Pillars - RF Punch component tweets.
B. Pillars - RF Prime component tweets.
Rear Doors - RF Punch 5.25" mids.
RF Punch 3-way passive X-overs.
Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS.
Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider.
Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS.
Box - 9.6 cu^3 net @35Hz, three 6" aero's.
Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand)
Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
The MB Quart was offered to me from a friend for $120 he has 3 of them bbut I have a $400 spending limit for a new amp, y'all got any sugestions.
I've got a 1000.1, it's been okay I guess. Really for the subs I ran it with full power would have been a bit much, so it worked well.
Definitely power hungry, and it makes a pretty bad humming noise. Overall though only had it protect on me once and I was asking for it, so it's been plenty reliable.
Lanzar OPTI2000D, CT Sounds 2200.1D and if you really want to go MaxxSonics and have it do the work, Hifonics Mt. Olympus. Many others, feel free to chime in guys!
Also, what subs are you running? That isn't a bad price on the MBQuarts, if your subs are 4ohm DVC, maybe one to each sub, 2ohm load on each amp?
He is looking for amps. Aren't TS-W3002SPL subs? lol
2 Pioneer TS-W3002SPL
he was responding to "what subs are you running?"
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
  • Who's Online   0 Members, 0 Anonymous, 704 Guests (See full list)
