Efficient 2k amp for under $350?
AstoSoup
Not many amps like .5 ohm, if they can they are well built, therefore will be a little more than $350. Unless you can find a deal used, you may look at selling the sub you have and get two with d4 coils so you can wire to one ohm. 2k amp at one ohm will be less.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
subs barely moving off a 1700? You really need to get that volt meter installed and see where voltage is at. Also, 2k RMS at 2 ohm will be much more than 350
This, and this.
2krms @ 2 is like a 3500wrms @ 1
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
I know 2k rated at 2ohms, for under $350 is kind of asking for the moon lol. I would go used if the seller was trusted and what not, especially if it was a DD, DC. What about amps that can do near 2k @0.5ohm though? I have not seen many but then again, I am no expert. The OPTI2000D looked promising, it dyno'd at 1960W RMS @0.5ohm but I think that was at 14.4v. I just wish I would have known I was going to want more when I purchased this sub, I would have got the D4ohm version :/
Head Unit - Clarion VX709 7" DVD Touchscreen
Mid/Highs - Front Doors - RF Prime 6.5" component mids.
A. Pillars - RF Punch component tweets.
B. Pillars - RF Prime component tweets.
Rear Doors - RF Punch 5.25" mids.
RF Punch 3-way passive X-overs.
Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS.
Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider.
Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS.
Box - 9.6 cu^3 net @35Hz, three 6" aero's.
Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand)
Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
Cant you just put a dmm on the amp to see what your voltage is at
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
aint nobody got time for details
:peepwall:
LMFAO so true
:blush:
I know! I am thinking my voltage is down there quite a bit and once I see just how much, it's on to figuring out why.
check your pm
I will as soon as I find it lol, new to this forum.
check your pm
refresh page, look at top by your name, little message icon.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
You could try kicker zx1500, fosgate t1500BDCP, and a few other choices. not quite 2k at 2 ohms, but probably all a solid 1500...btw your sub is a dual 2? then you only need a 1 ohm stable amp or am i missing something?
1997 Lexus ES300
HU - Pioneer MVH 7350
Processor - Helix DSP
Front Stage - JBL P660C
Mid/high amp - Alpine PDX-F4
Subs - 1 IA Death Penalty 12
Sub Amp - Cactus Sounds PF300.1
  • Who's Online   2 Members, 0 Anonymous, 876 Guests (See full list)
