Do I need a H/O alt??
You should ground your alternator directly to the battery, it helps. Since the alternator's negative current has to go through the engine block to get to the battery. I just switched my chassis ground to my alternator and it helped a ton.
If your running that much power, then yeah... You will want a high output alternator.
You should have both grounds not one or the other.
Yes, one to the engine block and the other to the alternator instead of the chassis...
You still need a chassis ground.
Ground everywhere, I have two grounds on both batteries under the hood. Two go to the frame, the others go right on the alternator casings.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I'm just saying the alternator ground takes priority over a chassis ground if you don't have the extra wire.
Alright I'll be looking into the alt. the only reason I haven't done it yet was due to the cost of books which depleted the alt fund.
Also, voltage stays strong and hasn't dropped into the 12's yet.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
  • Who's Online   0 Members, 0 Anonymous, 3191 Guests (See full list)
