port location?
tn2k
On the enclosure Is there a best location for a port? Front baffle, top, side, rear...
I understand that the vehicles interior can affect this but I was just curios about the enclosure itself...
There is no one best location it's all build dependent.
I should add that the enclosure in question would be in an explorer for now and later next year in a yukon/suburban and the woofer direction would be facing the rear of the vehicle...
In a Suv port facing toward the rear is usually best. An enclosure may not perform the same in two different vehicles so don't be surprised if you need to build a new one when you change vehicles.
I have to face the woofers to the rear. Stuff will inevitably sit on top of the box. (Child stroller etc...) So have the ports going towards the rear of the vehicle out of the same surface (baffle) as the woofers?
Yes.
No problem. You could also start a new post with your max dimensions to get help with a design if you need it.
  • Who's Online   1 Member, 0 Anonymous, 2887 Guests (See full list)
