strapping two incriminator audio ia 20.1
Anand Sayroo
Hi everyone, I have two american bass hd12d1s . I have a ia 20.1 but I'm thinking to get another 20.1 but I would like to know if i can strap the two amps together with those subs. I'm being told the amps will be stable at 2 ohms but my subs cannot be wired at 2 ohms. Any suggestions? or is there something that I'm missing. I'm looking at the manual and seeing a wattage linked at 1 ohm.
Yeah, the manufacture says it's only 2 OHM stable when they are strapped and they run 4800w RMS @ 2OHM. If 2400w @ 1 OHM isn't enough, then you need to look into a more powerful amplifier... Something like this:
http://www.amazon.com/Orion-XTR3700-1D-Monoblock-Series-Amplifier/dp/B00DDZTLZY
The specs says its stable at 1ohm, strapping two of them will give you a final load at 2ohms at about 4800, not sure if they do rated...
From the way I understand it, the final load is 1OHM per sub if he wires them according to the IA20 pdf manual.
http://www.incriminatoraudio.com/download/IASeriesManual.pdf
The minimum impedance of two strapped is 2ohms so if he goes below that then he my friend might need a fire extinguisher in his ride...I would just run one amp per sub to keep it simple....he can wire his subs at 2ohms then one sub per amp strapped at 2 ohms...
The amps are strapped it makes one big amp out of the 2
how can he wire Each sub to each amp???
Using the master mirror option..my bad it was late my thought process was off, if you want to run it at 1ohm per amp using the mirror option, you need D2 subs, but since he has D1s he needs to wire them at 2ohms per sub to each amp, but using the master/slave option he can do it but it'll have to be at 4ohms...so both subs with a final of 4 ohms then the to the amps
  • Who's Online   0 Members, 0 Anonymous, 1531 Guests (See full list)
