Are there any tips or tricks to cleaning chrome rims? Cause the standard way of cleaning them is getting pretty annoying...If there isn't well I guess I'll have to live with it.
Currently whipping a O4' GMC Sierra 2500
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
Flowmaster Super 10's
Magnaflow High Flow Cats
G2 4:88 running gears
New cooling system
Superchips Flashpaq programmer
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
8 Gauge Memphis Power wire
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
38x13.5 Toyo Open Country M/T's
18x10 Fuel Mavericks (-44 offset)
Diamond plate bed gaurds
Diamond plate tool box
Recon Xenon Bulbs in Highs,Lows,& Fogs
Recon LED Tail lights
AMP Research Automated steps
I use this, extremely fine and does an incredible job on taking anything and everything off that's on there. Some people are for using it, and some against, but you can't argue with the results and I've used it for a long time with no negatives to come with it.
Chrome is easy, use this:
http://www.detailing.com/store/meguiar-s-hot-rims-chrome-wheel-cleaner-24-oz.html?gclid=CjwKEAjw8O2hBRDKur2lseLW6C8SJAC-r1J3to11dd44QMGM4DegguLa-wJokz9KXE1IgGC01-2zQhoCPJ3w_wcB
Be glad you don't have Billet. Aluminum wheels are much, MUCH more of a pain in the ass than chrome.
Should I also buy the wheel cleaning brush or is it a waste of money?
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
Do you have a mitt with those microfiber fingers/tentacles? A brush is not needed and I've never found it necessary, even I heavy build up and tar/grime.
No I do not...I'm guessing I should pick one up.
Performance:
K&N Cold Air Intake
Hedman headers
3" True duels
New cooling system
Eaton lockers
Audio: JL CP208W3V3
Kenwood X500-1
Kenwood DDX8901HD
Exterior:
Fabtech 9.5" lift
The mitt is nice to have for washing the car at the house. Ever since they started making one, I have had one. The microfiber is gentle enough but scrubs well for the paint. The downside to the microfiber is that you need to make sure it's CLEAN between uses. Those little bastards hide little hard nuggets of leaves, twigs, dirt, etc. You have to almost pressure wash them to clean them.
What about black rims
I scrub mine with soapy water and a sponge then rinse, then I spray them with windex and wipe them down with a microfiber towel.
  • Who's Online   0 Members, 0 Anonymous, 1032 Guests (See full list)
