chicopup26 Posted October 16, 2014 Report Posted October 16, 2014 I've got a soundqubed 1200.1 with a hdc3 15 I just got my hands on a soundqubed 120.4 My electrical situation is 160 amp alt Duracell gold 1/0 shca ofc big 3 I want to get the 120.4 installed, but I'm not sure on what I'll need electrically Can I have a run of 1/0 and use a distribution block for both amps? What specs on a battery should I buy (Don't know how to ask this without making it a "versus" thread)
islandpride684 Posted October 16, 2014 Report Posted October 16, 2014 I've got a soundqubed 1200.1 with a hdc3 15 I just got my hands on a soundqubed 120.4 My electrical situation is 160 amp alt Duracell gold 1/0 shca ofc big 3 I want to get the 120.4 installed, but I'm not sure on what I'll need electrically Can I have a run of 1/0 and use a distribution block for both amps? What specs on a battery should I buy (Don't know how to ask this without making it a "versus" thread) Download the xs power app or go to 4xspower.com and input your info...it will tell you what you will need...also you can use a distro block to split the power wire into both amps Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
chicopup26 Posted October 17, 2014 Author Report Posted October 17, 2014 The wire thing I was more asking if the 1/0 had the ampacity for both amps
Goingdef1310 Posted October 17, 2014 Report Posted October 17, 2014 You should be able to the best way to tell would be to add up the total fuse ratings for both amps then check to see how many amps of current you can pull through the length of wire you have in your car then fuse it accordingly.
chicopup26 Posted October 17, 2014 Author Report Posted October 17, 2014 200 amps total, I'll have to find an ampacity chart. I just wasn't sure if anything is different in car audio wire
Broke_Audio_Addict Posted October 17, 2014 Report Posted October 17, 2014 Are you using the 1/0 skyhigh ofc for the run or something different? That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
