headunit preamp gone bad?
so you have only one set of rca's connected to your headunit and they are going to the sub amp? if your phone has a headphone jack/connection get/borrow a cord that had a headphone jack to rca connection and plug it straight into your amp. have you tried moving things around near your amp while it's doing this? is the sound coming from the speakers that are run from the headunit or the amp.... need more info to help more sorry man
i edited the main post to make more sense
2006 Pontiac G6 3.5L
Pioneer AVH-X5800BHS DVD Receiver
Singer 320 amp alternator
Crescendo audio hp120 battery
Crescendo audio bc3500d
Crescendo audio s550/2
Crescendo audio s1100/2
2 Sundown audio zv5 12
Rockford Fosgate 440-4D
5 cubic foot octoport tuned to 35 hz
4 crescendo audio pwx 8s
2 crescendo audio pwx 6.5
4 crescendo audio ft1 super tweeters
2 crescendo audio Symphony coaxial 6x9
ahh okay put the rca's back on the sub output and set the decks lpf at 80 or so..... you still havn't told me how many amps your running or if the speakers are run from the headunit. is the sub the only this that's being weird?
also worth trying to see if it does it with just a cd or usb without letting your phone connect to it via Bluetooth............ if ya cant be bother'd trying all this stuff just grab another deck and hope it goes away
:P
correct i only am using the sub channel and its going to my fahrenheit amp thats connect sub, and the pulsing is only coming from the speaker connected to the rca output from the back of the headunit, but like i said when i used the front l and r output and rear l and r it did not do it when i hocked up the full range speaker and amp
:P
yes it still did the pulsing it even did it with the radio.
Try the front or rear output of the deck going to your sub amp, not a different amp. You're adding another variable by doing that.
  • Who's Online   0 Members, 0 Anonymous, 975 Guests (See full list)
