nathanb5533 Posted October 17, 2014 Author Report Posted October 17, 2014 all of my setup is from 1994 except head unit and is mint everything is or was working, 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
SIDE SHOW Posted October 17, 2014 Report Posted October 17, 2014 nah nah nah now I no it has more than one amp, i'd suggest it is a ground loop issue through your rca's. as when you only have one set of rca's connected to your headunit either the sub amp or the fullrange amp the issues go away, soon as you add the second/third set of rca's its creating a ground loop. with more info it makes finding problems so much easier
islandpride684 Posted October 17, 2014 Report Posted October 17, 2014 yeah he's edited his first post since I have read it..... thanks for pointing that out You should wait a couple seconds before hitting reply again...lol Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
nathanb5533 Posted October 17, 2014 Author Report Posted October 17, 2014 nah nah nah now I no it has more than one amp, i'd suggest it is a ground loop issue through your rca's. as when you only have one set of rca's connected to your headunit either the sub amp or the fullrange amp the issues go away, soon as you add the second/third set of rca's its creating a ground loop. with more info it makes finding problems so much easier hold on but i only have the one amp hooked up until i fix this issue, your getting the wrong idea 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
nathanb5533 Posted October 17, 2014 Author Report Posted October 17, 2014 im just gonna go with we will find out the issue when i send my headunit in for repair if it works after then great if not then ill solve it then 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
SIDE SHOW Posted October 17, 2014 Report Posted October 17, 2014 lol righto.... lets hope for your sake it is the headunit (I don't think it is) but im only guessing as I cant see the system. hope ya sort it
islandpride684 Posted October 17, 2014 Report Posted October 17, 2014 im just gonna go with we will find out the issue when i send my headunit in for repair if it works after then great if not then ill solve it then You probably blew the pico fuse on the headunit...so my guess is that and the way to fix it is to ground the rca connections in the back of the head unit, or solder the two points on the pico fuse together or send it in and a get a new one...pioneer head units are known for that... Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
nathanb5533 Posted October 17, 2014 Author Report Posted October 17, 2014 im just gonna go with we will find out the issue when i send my headunit in for repair if it works after then great if not then ill solve it then You probably blew the pico fuse on the headunit...so my guess is that and the way to fix it is to ground the rca connections in the back of the head unit, or solder the two points on the pico fuse together or send it in and a get a new one...pioneer head units are known for that... no i checked the fuse 2006 Pontiac G6 3.5L Pioneer AVH-X5800BHS DVD Receiver Singer 320 amp alternator Crescendo audio hp120 battery Crescendo audio bc3500d Crescendo audio s550/2 Crescendo audio s1100/2 2 Sundown audio zv5 12 Rockford Fosgate 440-4D 5 cubic foot octoport tuned to 35 hz 4 crescendo audio pwx 8s 2 crescendo audio pwx 6.5 4 crescendo audio ft1 super tweeters 2 crescendo audio Symphony coaxial 6x9
