rca splitters or what ?
Pass through are nothing more then a built in y adapter.
So in essence, there is no such thing as a TRUE 4ch. output on an amp? If a pass through is just a Y adapter, only the first amp will balance/fade, not the second.
Head Unit - Clarion VX709 7" DVD Touchscreen
Mid/Highs - Front Doors - RF Prime 6.5" component mids.
A. Pillars - RF Punch component tweets.
B. Pillars - RF Prime component tweets.
Rear Doors - RF Punch 5.25" mids.
RF Punch 3-way passive X-overs.
Mid/Highs Amp - MB Quart Onyx 360.4, 4 channel, 640W RMS.
Subs - (2) PowerBass 3XL 15, 1000w RMS, 3" flat wound coil, 562oz motor, 10" spider.
Sub Amp - Audiopipe GD6001 @.5ohm, clamped 2825RMS.
Box - 9.6 cu^3 net @35Hz, three 6" aero's.
Charging - Energizer 120Ah AGM under the hood, MaxLife 75Ah in the rear. Big 3, 140A aftermarket alt. (off brand)
Wires - Two JL Audio 2/0ga OFC. runs to rear, 4ga. power/2ga. ground to component amp (OFC), 1/0ga. OFC Knu Konceptz Kolossus Kandy everywhere else.
A 4ch amp with pass through would have 4 inputs 2 outputs.
00 front right and left
00 rear right and left
00 pass through right and left.
So
Eq
00 front out put to highs
00 rear out to 2 y adapters (1 male to 2 female) turning that output into a
Left side 0 --> 00
Right side 0 --> 00
So now the rear output has been altered to where it has 2 left and 2 right outputs.
Use one set of rear out puts to the mid range
Use the other set of out puts to mid bass
Use the third output on the amp
00 for Sub(s)
Or
Eq
00 front
00 rear
00 sub
Fro t to highs
Rear to midrange pass through from midrange to midbass
Sub to sub.
Either way the fade effect will only work as I turns the highs down and the kids up when faded to the rear or vice versa the other way around. Left and right speaker separation would still exist.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
So
Eq
Left side 0 --> 00
Right side 0 --> 00
00 for Sub(s)
Or
Eq
00 front
00 rear
00 sub
Fro t to highs
Sub to sub.
First option seems the most logical... You got into that way more than I was about to, props lol.
Yes indeed that sounds like a good idea but the nvx doesn't have one of those pass thru's and ive looked on sonic electronics and ive only seen one so far that has the power and the pass thru that I need I just dont know if it does rated power is the hifonics x800.4 cuz I was gona wire the speakers like this. First amp to mids and highs second amp with the first 2 chanles for the prv mid bass and bridge the other 2 channles for the 8"woofer so sub amp for the back and 2 4 channels with one for mids highs 2nd for mid bass and other sub for center console and who ever said they had the diagram ready to go can I see it plz thnx alot for yalls input on this its really helping me out
Ok so I cant achieve this with the nvx amps can I do it with hifonics x800.4
Achieve what? You don't need a pass thru, it's a plus if it comes with it...did you look at the diagram at least...
  • Who's Online   0 Members, 0 Anonymous, 1145 Guests (See full list)
