boom50cal Posted November 8, 2014 Report Share Posted November 8, 2014 schedule 40 6 and 8 inch PVC should be available at any commercial plumbing suppy stores(such as Locke Supply). Hair dryer isn't near hot enough, heat gun can work, but the best, in my opinion, is a small torch. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
BRodgers Posted November 8, 2014 Author Report Share Posted November 8, 2014 Make sure that your seal off is not leaking, your box looks ok but can be done more efficient no doubt and don't know how's your bracing inside (maybe pics of the whole setup?). Have you metered? RTA? any numbers? 2001 Dodge Intrepid R/T 2 American Bass XFL 12's American Bass VFL 150.1 Exide Group 31 AGM Big 3 1/0 Bullz Audio Link to comment Share on other sites More sharing options...
Joe X Posted November 8, 2014 Report Share Posted November 8, 2014 You can do a few tweaks and gain from them, port area is somewhat low and net vol could be improved, you could do aeros and improve also, could up tuning a bit to 35Hz, you may gain a few dBs at most, if that's all you want you will get it, if you want to double your output on tweaks don't think it's happening at least for a daily type of setup nice on music, if you want vast improvement you will need to move to other equipment, honestly a couple of 19mm xmax subs can't do it all. If your seal off is good opening your trunk will result in no changes in output in the cabin. Link to comment Share on other sites More sharing options...
Aj11 Posted November 8, 2014 Report Share Posted November 8, 2014 the last 5 boxes I've done I've wanted to use 6 or 8inch pvc. in my area its just not around. the one place that i could get 8inch from was a 3 ring circus to get it. they needed to special order it, it Was $55 for the full section, plus shipping and they said they wouldn't cut it Down for me. I'm not spending almost $100 bucks when i can get a psycho port. i just went with sono instead. I'm sure not all areas are like mine. but here its almost impossible jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out) Link to comment Share on other sites More sharing options...
boom50cal Posted November 8, 2014 Report Share Posted November 8, 2014 Around here it's not too hard to get it, the 90 elbows are the expensive parts though. $38 a piece for 90 degree 6 inch elbows. 20ft of schedule 40 6 inch is only $20 here. On 1/4/2013 at 9:31 PM, HatersGonnaHate said: Wow. 184 posts and I think you're a fucking asshole. Link to comment Share on other sites More sharing options...
BRodgers Posted November 9, 2014 Author Report Share Posted November 9, 2014 I can get an 8" Sono Tube in a 4 foot length for $5 at Menards. I went out and checked today. Joe If I were to completely re-do my box and I went for 4.5^ft to 5^ft and used a single 8" Sonotube and could get it tuned to 33hz would that be more efficient and would I gain db's over my current box do you think? I know the sealed off trunk sounds the smae with trunk open or closed so I know that's a good seal. 2001 Dodge Intrepid R/T 2 American Bass XFL 12's American Bass VFL 150.1 Exide Group 31 AGM Big 3 1/0 Bullz Audio Link to comment Share on other sites More sharing options...
BRodgers Posted November 9, 2014 Author Report Share Posted November 9, 2014 How about this...Using an 8" Sonotube? 2001 Dodge Intrepid R/T 2 American Bass XFL 12's American Bass VFL 150.1 Exide Group 31 AGM Big 3 1/0 Bullz Audio Link to comment Share on other sites More sharing options...
Joe X Posted November 9, 2014 Report Share Posted November 9, 2014 I would go for psychoports or PSP ports, flares are really important to round port performance. Also you should have good clearance of the port to the backwall, around 1 diameter, if you go below that you will need to test for choking. On the net volume I would need to get back to you on how much you can do without inflicting damage, have you clamped the amp? are you upgrading power later? YES you can gain over what you have now but as before, likely a moderate gain. Link to comment Share on other sites More sharing options...
BRodgers Posted November 9, 2014 Author Report Share Posted November 9, 2014 I haven't clamped the amp or tested the db's on a meter. It's pretty wicked already just trying to get the most out of them as possible. I have an Exide Agm group 31 and the big three done with Bullz audio 1/0 gauge 2001 Dodge Intrepid R/T 2 American Bass XFL 12's American Bass VFL 150.1 Exide Group 31 AGM Big 3 1/0 Bullz Audio Link to comment Share on other sites More sharing options...
Aj11 Posted November 9, 2014 Report Share Posted November 9, 2014 sonotube aren't.that hard to flare. only thing is you need to cut the hole in your front baffle then mount the tube flare both ends then mount to the box. 2 heat Lamps some fiber glasd and paint. not much money or work. jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out) Link to comment Share on other sites More sharing options...
