Box done + stencil & paint and tried to rewire like pro's do
fufhubbin
INSTALLED metal slats the bridge my bass shaker to my seat and it nearly doubled the output from before where it was just mounted to the floor of my car. this is the best bass shaker on the market. its the buttkicker LFC but this brand paid them for their name to be on it . they are truly unique and add a feel of a shit ton of bass
Does the bass shaker provide more of the low, rumbly bass or the tight, punchy bass feeling? I have a friend who has been talking about getting one for a while. You make it sound quite appealing.
It honestly provides both! can be very tight and punchy and also low and rumbly depending on the note. since it seems likes its just a massive vibrator you would like its not accurate at playing different notes but it really is a good job. it makes the seats shake a shit ton and doesnt feel completely artificial feels like its the system ha but ive noticed it doesnt really shake my rear view mirror that much and my sub can shake the mirror a good bit on 1/4 volume even thou its 2 times as farther from the mirror
ORION HCCA 10.4 2000 watts RMS 4000 watts max
hifonics brutus 2600 bxi
Alpine IDA -305 Digital receiver
0 gauge power wire 250 amp fuse
800 watt BUTTKICKER BASS SHAKER
Kicker zx-400 amp to power buttkicker
Dat amplifier mounting job doe...
Are you serious or just trolling with all of those screws?
Just saying man. Buy a alarm sir. Get a dog ? Look like your learning. Yeah screws on amp is a little over the top. Looks loud.
agreed ha i forgot about that so i bought the amp on craigslist for 200$ a few months back and the guy said the bottom came off or something idk and he had to mount it to a board. there was nothing to secure it to the board really so i guess he put about 10 screws at angle on each side to hold it in lmao its kinda ridiculous looking.
idk if the bottom of the amp is off completely or the bottom is loose so its mounted to the board to hold it on but it used to run hot when i just had 4 gauge and i had no issues
I had that exact same distro. Caused my voltage to drop like crazy
which one should i get then. its been fine for me so far but i havent been pushing it to the max much. i do have the voltage meter hooked up to the IN power on the distro block thou to keep an eye on it.
is there a way to turn up the idol on a car cause i have to turn it down at stop lights since my cars idols around 400-500 rpms i would like 700-900 maybe
the octagon 1 is my ground and my power is an xscorpian 1 that i thought was quality which one were you talking about. can a shitty ground distro caus voltage drop or hot amp/s
it can... poor grounds (any connection that's poor really) loses energy as heat and obviously can't support as much power as a proper connection
ground runs are just as important as positive power runs. They are 2 sides of the same coin.
That's what it looked like to me: Bottom of the amplifier fell off, replaced it with wood. As long as you didn't do it, and understand how bad of an idea that is.
You should probably get rid of the amplifier. There's probably no vents in that board, and I'll say that the original bottom probably had holes in it so it's going to get hot, and maybe one day fry.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
  • Who's Online   0 Members, 0 Anonymous, 3292 Guests (See full list)
