SMD Basshead Posted November 9, 2014 Report Posted November 9, 2014 Ok guys..first off, I'm sorry if this is the wrong section but, I bought a sub and I now need an amp for it. It's a RE SEX12D4. Can anyone suggest something? This is a learning process for me so..bare with me. >.< Edit - What gauge wire should I run? Proud owner of a 1982 Mercedes 300D TurboDiesel Xbox GT - SMD Basshead
Aj11 Posted November 9, 2014 Report Posted November 9, 2014 you.mean a re sxx d4? i won't judge how your phone just put sex in there for you... ; ) but that sub is 1000w sub... so get a amp that's 800-1200w @ 2ohm. or get a 2000w amp that does power @1ohm. then you'll have the 800/1000w available at 2ohm but if you want to add another sub you'll have enough power for 2 subs. and allways get 0g wire, if the amp doesn't take 0g just get a distro Block. we can't tell you which brand is better then the other, but give us your budget and well help jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
SMD Basshead Posted November 10, 2014 Author Report Posted November 10, 2014 Nah man, no auto correct. http://www.sonicelectronix.com/item_68086_RE-Audio-SEXv2-12D4.html Budget? Keep it down below $200 or so. Proud owner of a 1982 Mercedes 300D TurboDiesel Xbox GT - SMD Basshead
Miguels Posted November 10, 2014 Report Posted November 10, 2014 a saz1500 a crescendo s1500 oe any on that range.. it gives you the option to add a sub at a later time my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
islandpride684 Posted November 10, 2014 Report Posted November 10, 2014 http://www.soundqubed.com/Q1-750-Amplifier_p_46.html Build Log http://www.stevemeadedesigns.com/board/topic/186921-blk9te-07-yukon-slo-mo-build/page-3?hl=%2Bblk9te#entry2881410
bcbrassard Posted November 10, 2014 Report Posted November 10, 2014 Nah man, no auto correct. http://www.sonicelectronix.com/item_68086_RE-Audio-SEXv2-12D4.html Budget? Keep it down below $200 or so. Your budgets a bit low sir.
SMD Basshead Posted November 10, 2014 Author Report Posted November 10, 2014 Ok so the sub says on the website 'Independence - Dual 4 Ohm' Would this one be ok? http://www.sonicelectronix.com/item_68065_RE-Audio-DTX-1600.1.html Proud owner of a 1982 Mercedes 300D TurboDiesel Xbox GT - SMD Basshead
SMD Basshead Posted November 10, 2014 Author Report Posted November 10, 2014 Nah man, no auto correct. http://www.sonicelectronix.com/item_68086_RE-Audio-SEXv2-12D4.html Budget? Keep it down below $200 or so. Your budgets a bit low sir. I know, trying to do a budget build. Proud owner of a 1982 Mercedes 300D TurboDiesel Xbox GT - SMD Basshead
