Well this is what I get for leaving every thing for the last minute (literally)...I need to be at a show in less than two hours and still need to burn a CD to use...
Can't find every test tone like I had before so I was going to play a swine sweep from 35hz-50hz...Sounds ok to you guys?
nope..use that sweep to find your frequency, then when your at the show, use that frequency to burp with.
If you use a sweep in a comp your score will not be as good.
Follow my Tweet (Twitter)
Gotta agree, using sweeps heats your coils up quick and it also pulls battery power :o, so by the time you get to the sweet spot, your coils are hot and your batts area semi drained. :-[  Trust me, I learned it the hard way. :'(
48956a0.jpgwww.competitionsoundz.comTeam R&RTeam MaxxsonicsTeam DC AudioTeam PowermasterTeam KinetikHooker car audio
he actually explained it better than i did ^^^  ;)
Ah damn we ended up using it since we had nothing better to play with besides music...
Still pulled off a 149.1
not bad at all :^
......was it with a TermLab sensor?
